HRSP Question.
nguyenvinnie
We have a pair of 6509s that configured HRSP on Vlan 100 (Voice) and we are adding another 6509 that will also carry Vlan 100. How do I go about configuring the 3rd 6509?
Giuseppe Larosa
Hello Vinnie,
you can add it to the same group it can be the third router and will state in HSRP listen state (listening to the other two HSRP hellos).
Or you can think to move to GLBP to have some load balancing (host/phone based using ARP activity).
Hope to help
Giuseppe
I will add it to the HSRP group.
