ASR1001-X Licensing Issue - License installation failed with error: XML parsing failed
Alex Pfeil
Level 7
Level 7
I was getting an error today when I was installing a license on the ASR1001-X. The error is shown below.
IPSEC#license install bootflash://NCSFEAT201706151321538670.lic
Installing licenses from "bootflash://NCSFEAT201706151321538670.lic"
% Error: License installation failed with error: XML parsing failed
I ended up using  the license right-to-use move securityk9 command instead of installing the license and I wanted to share this so someone may have easy access to this possible solution.
IPSEC#license right-to-use move securityk9
% End User License Agreement is not accepted
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO PRODUCT FEATURE OR USING SUCH
PRODUCT FEATURE CONSTITUTES YOUR FULL ACCEPTANCE OF THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Activation of the software command line interface will be evidence of
your acceptance of this agreement.
ACCEPT? (yes/[no]): yes
Moved the license securityk9 from evaluation to permanent mode
show license | b securityk9
Index 41 Feature: securityk9
Period left: Life time
License Type: RightToUse
License State: Active, Not in Use, EULA accepted
Please comment.
Alex
0 Replies 0
