I have a request whereby they need 50,000 maximum sessions on a 5Gig connectivity.
i did the excersice based on 1006 (looking at the link: http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/scaling_ps9343_TSD_Products_Configuration_Guide.html
and http://www.cisco.com/en/US/prod/collateral/routers/ps9343/product_bulletin_c07-448862.html#wp9002749
but none of them has an exact answer for the ASR1002-X, in the first link "scaling" it says the 1002-X can handle maximum 12,000 PPP sessions, while in the CCW config you can select 64,000 or more without it giving you a warning?
how can we get the right answer here?
1006 config is as follows:
| SKU | Description | Quantity |
| ASR1006 | Cisco ASR1006 Chassis Dual P/S | 1 |
| CON-SNT-ASR1K6 | SMARTNET 8X5XNBD Cisco ASR1006 Chassis Dual P/S | 1 |
| ASR1000-RP2 | Cisco ASR1000 Route Processor 2 8GB DRAM | 1 |
| CON-SNT-ASRRP2 | SMARTNET 8X5XNBD ASR1000 RP2 | 1 |
| M-ASR1K-RP2-16GB | Cisco ASR1000 RP2 16GB DRAM | 1 |
| ASR1R2-AIS-38S | Cisco ASR 1000 Series RP2 ADVANCED IP SERVICES W/O CRYPTO | 1 |
| CON-SNT-ASR1R2AI | SMARTNET 8X5XNBD Cisco ASR 1000 Serie | 1 |
| M-ASR1K-HDD-80GB | Cisco ASR1000 RP2 80GB HDD | 1 |
| ASR1000-SIP40 | Cisco ASR1000 SPA Interface Processor 40 | 1 |
| CON-SNT-1000SP40 | SMARTNET 8X5XNBD Cisco ASR1000 SPA Interface Processor 40 | 1 |
| SPA-10X1GE-V2 | Cisco 10-Port Gigabit Ethernet Shared Port Adapter | 1 |
| CON-SNT-10X1GEV2 | SMARTNET 8X5XNBD 10-Pt Gigabit Enet Shared Pt Adptr | 1 |
| GLC-LH-SMD | 1000BASE-LX/LH SFP transceiver module MMF/SMF 1310nm DOM | 1 |
| GLC-SX-MMD | 1000BASE-SX SFP transceiver module MMF 850nm DOM | 1 |
| SFP-GE-T | 1000BASE-T SFP (NEBS 3 ESD) | 1 |
| ASR1000-SPA | SPA for ASR1000; No Physical Part; For Tracking Only | 1 |
| ASR1013/06-PWR-AC | Cisco ASR1000 1600w AC Power Supply | 2 |
| CAB-1900W-UK | Power Cord 250 VAC 13A BS89/13 Plug UK | 2 |
| FLASR1-BB-RTU | Broadband Right-To-Use Feature Lic for ASR1000 Series | 1 |
| CON-SNT-ASRBBRTU | SMARTNET 8X5XNBD Broadband Right-To-Use Feature Lic for A | 1 |
| FLASR1-BB-64K | Broadband up to 64K Sessions Feature Lic for ASR1000 Series | 1 |
| CON-SNT-FLASRB64 | SMARTNET 8X5XNBD Broadband up to 64K Sessions Feature Lic | 1 |
| ASR1000-ESP40 | Cisco ASR1000 Embedded Services Processor 40G | 1 |
| CON-SNT-ASR1000E | SMARTNET 8X5XNBD Cisco ASR1000 Embedded Services Processo | 1 |
