Monitoring tools?
Andrew White
Level 5
Level 5
I'm using Netflow and Solarwinds Orion NPM at work to monitor routers and servers and ports on switches, one of the tools that is great is the real-time bandwidth gauge tool which lets me see how much bandwidth a port is using on a server or router via SNMP, does anyone know of a free tool that can do this or recommend any other tools that may be of use that you use that are free so I can use on my home lab?
6 Replies 6
John Blakley
Andrew,
MRTG is an excellent tool for this:
http://oss.oetiker.ch/mrtg/
Or if you're wanting more of a website feel, you can use Cacti that also incorporates MRTG:
http://www.cacti.net/
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks guys, I will check these out.  How oftern they update there stats?
I'm after a way to show what the bandwidth of a port on a router or switch is doing evey 5 seconds?
Solarwinds do one as part of their Engineer Tools, but it costs a lot of money.
johnlloyd_13
Level 11
Level 11
I use PRTG on my home lab. I believe it can monitor around 5 devices on the free version.
Don Jacob
Level 7
Level 7
You could use SolarWinds Free Real-Time NetFlow Analyzer - it is a standa lone free module and does not need NPM. Could be ideal for your lab use - is free and you are already familiar with us.
If you want to explore further, there are free offerrings from Plixer Scrutinizer, ManageEngine NetFlow, etc.
Don Thomas Jacob
Head Geek @ SolarWinds
NOTE: Please rate and close questions if you found any of the answers helpful.
Disclaimer: I work for SolarWinds
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
anirudh.wna
i think mrtg or cacti are one of the best ones..
kcsureshbabu
Community Member
MRTG is best
