ASR1K "show interface counters error" command not found.
Not applicable
hello.
Are there any command interface counter errors in the Cisco ASR1K series?
I want to see errors. Is there any way I can see them?
You need to confirm that it has been replaced by another command.
Please help me.
Mark Malone
Different commands for troubleshooting drops on ASRs , this doc explains how it works with the commands
http://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/110531-asr-packet-drop.html
Thank you for your answer.
You mean there are no similar commands like " show interface counter error"?
I only wanted to filter it separately, but I feel sorry.
Hi no not exactly its different I haven't seen a general command like that that you can see all interfaces at once with the ASRs , that doc contains most of the hardware platform commands that will allow you to see the same type of errors but there very different from standard routers like 7200s or 4000 series
the only counters command im aware of that's global is but as its says it just showing you what protocols are enabled per interface
xxxxxxxxxxxx#show int counters ?
  protocol  interface protocol counters
show int counters protocol status
