Assigning an IP address to a fastethernet port on a NM-16EWS-1GIG card
manuel.dennis
I am trying to implement a 3845-SRST/K9 with a NM-16EWS-1GIG RJ-45 port card under IOS 12.4(24)T4.
When I attempt to assign an IP address to a fastethernet port I get a response that the card is L2.  Is this correct?  Is the card only L2 capable, or can I do something in the IOS, so that I can assign IP addresses to the ports?
The port is on the switch module but it configurable from router IOS and so you just type  int fx/x and under it no switchport
and then you can give it an ip address.
Regards.
Alain.
7 Replies 7
cadet alain
To assign an ip address to  this interface you must make it a routed port( by default it is a L2 port, remember this is a switching module) by issuing the interface command  no switchport then you can do ip address x.x.x.x
Regards.
Alain
Alain,
Thanks.  It never occurred to me that a router would behave like an unmanaged switch.  I looked at the IOS 12 command reference and it shows the command implemented at the switch level.  On a router, do I implement it at the router level or the port level?
Manny
Regards.
Alain.
Alain,
I used the sequence:
config t
interface fastethernet1/n
no switchport
ip address nnn.nnn.nnn.nnn  255.255.255.n
and it worked, but I had to do it for each port, which was a pain.
Manny
You could have done it with the interface range command.
http://www.cisco.com/en/US/docs/ios/12_2/interface/command/reference/irfinter.html#wp1052019
Regards.
Alain.
i think you can do no switchport on multiple interfaces with command interface range fa0/1-5.
guruvignesh
Hello Manuel,
The NM-16EWS-1GIG card is Layer 2 (L2) and does not support assigning IP addresses directly to its ports. To use IP addresses, connect it to a router with Layer 3 capabilities.
