Assignment has me stumped, DHCP failed
lucasshane272
Student here, i am trying to connect my laptops to the wireless router connected to the Authentication server and for some reason my laptops connected at one point after 6+ hours of trying to find a cause and then they just, disconnected... its a bit messy from all the process of elimination but can someone please give pointers?
@lucasshane272
 Very simple problem. The RADIUS server you put on the Wireless Router is wrong. It must be 192.168.0.6 and not 192.168.0.7.
5 Replies 5
Reza Sharifi
Check the lease time on the DHCP
it is set to 24 hours
Martin L
PT is just a sim; Wireless is not always working as it should; see wireless sample from PT > File >open samples
and check CLN
community PT and CCNA forums at
https://learningnetwork.cisco.com/s/communities
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
@lucasshane272
I have found this to be the solution thankyou very much !
