04-10-2012 01:58 AM - edited 03-07-2019 06:02 AM
Hello community,
I need to upgrade a Catalyst IOS, but I got a bit confused. The catalyst is currently running "c2960-lanbase-mz.122-35.SE5.bin", but I want to upgrade to "c2960-lanbasek9-mz.122-35.SE5.bin", in order to enable ssh.
#sh ver
(irrelevant output is omitted)
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
Model number : WS-C2960-48TC-L
#dir flash:
Directory of flash:/
2 -rwx 736 Apr 4 2012 12:01:23 +03:00 vlan.dat
3 -rwx 5 Apr 10 2012 09:50:26 +03:00 private-config.text
5 -rwx 7508 Apr 10 2012 09:50:26 +03:00 config.text
6 drwx 192 Mar 1 1993 02:07:21 +02:00 c2960-lanbase-mz.122-35.SE5
So in flash there is a directory which contains:
#dir flash:c2960-lanbase-mz.122-35.SE5
Directory of flash:/c2960-lanbase-mz.122-35.SE5/
7 drwx 4480 Mar 1 1993 02:05:52 +02:00 html
623 -rwx 5222733 Mar 1 1993 02:07:21 +02:00 c2960-lanbase-mz.122-35.SE5.bin
624 -rwx 476 Mar 1 1993 02:07:21 +02:00 info
32514048 bytes total (24162304 bytes free)
What are the appropriate steps in order to upgrade to "c2960-lanbasek9-mz.122-35.SE5.bin". I have downloaded the tar file (c2960-lanbasek9-tar.122-35.SE5.tar)
1) Do I have to delete the old directory (drwx 192 Mar 1 1993 02:07:21 +02:00 c2960-lanbase-mz.122-35.SE5)?
2) Are these the correct steps to download and extract the IOS?
archive download-sw tftp://ip_address/2960-lanbasek9-tar.122-35.SE5.tar
verify flash:c2960-lanbasek9-mz.122-35.SE5.bin
wr
reload
3) Where will the tar files be extracted? Will an new directory be made or do I have to make one manually?
Thank you in advance,
Katerina
Solved! Go to Solution.
04-10-2012 02:22 AM
The "archive" command is an automated command which instructs the IOS to "unzip" the TAR file into a subdirectory.
If you are using the filename "2960-lanbasek9-tar.122-35.SE5.tar" then the IOS BIN file will be unzipped to the subdirectory called "2960-lanbasek9-tar.122-35.SE5".
You can then verify using the command "verify /md flash:2960-lanbasek9-tar.122-35.SE5/c2960-lanbasek9-mz.122-35.SE5.bin"
Your archive command does not contain the switch "/overwrite" which means that you will have TWO IOS files in your switch.
04-10-2012 02:22 AM
04-10-2012 03:21 AM
Thank you for your response!
I also found this interesting pdf
which provided a very good explanation!
I managed to upgrade without any trouble
04-10-2012 03:16 PM
Thanks for the ratings Katerina.
