asymmetric routing
ney25
Level 2
Level 2
Hi NetPros,
Good Day :) , well i have a question about the asymmetric routing traffic problem , recently my network performance feel very slow takes almost 1 hour only can upload 1 file. this wasn't happened before (Cisco and HP have confirmed this is caused by Asymmetric Routing , once you adjust the mac-address agingtime to 14,440 or higher then problem can be solved). my question is why the Asymmetric Routing problem came out suddenly ? is that any documents or link can i refer to ? basically management wants to know the root cause of this. so i wish those NetPros can share with me about your experiences .
thanks a lot and your reply will be really higly appreciate.
regards,
Jack
Hi Joseph,
thanks for your information.
regards,
Jack
