Asymmetrical Routing + ARP + HSRP issue
nicholas.pace
Good morning,
I have 2 CRS-1 Routers configured for HSRP which act as default gateway to 4 Cisco 2511 network consoles.  In this configuration, we have asymmetrical routing setup, so inbound traffic goes from R1 ----- towards cisco 2511 network consoles (4 of th em) which hang off a single 3750.  When the 2511''s access the internet, they travel over the same layer 2 circuit but towards R2 and this is the active router within HSRP.
My problem!!
When the 4 network consoles are rebooted, they arp to the subnet and everything works fine howver, when the arp time-out expires on the routers, communication is lost to the consoles and arp is never re-learned from the routers.  I check the debug on the consoles and can see the arp requests come in from the routers, but I think when it sends back its request, to goes to R2 (which isnt the one requesting arp.. its R1 --- remember traffic flow).
When we lose communication to the 2511 and I console into it, its arp table looks fine but it can't ping any of the HSRP Ips.
I know that I could put in static arps for these consoles but this is not an option in our network.
I'n very stumped here and would appreciate any assistance.
15 Replies 15
nicholas.pace
Additionally:
If I clear the mac address table on any of the network consoles, I will re-learn all of the same mac addresses and connectivity will be restored until the arp time expires on the routers.
Also:
If I plug a network console directly into the MPLS switch (green area of diagram) all of these issues go away.  So it seems that the 3750 switch could be the cause of this issue.
Jon Marshall
Nicholas
Can you post visio as jpg.
Is the 3750 only connected to one router ?
Which link is blocking with STP ? or are you running HSRP via the 3750 ?
Jon
Hi Jon,
The routers are connected via Alcatel MPLS (only using layer 2).  STP is not enabled on any of these devices and layer 2 redundancy is handled by alcatel.  the 3750 is connected to both routers via mpls.  hsrp is not enabled on the 3750, and the 3750 is providing only layer 2 comunication.
Nicholas
I don't think the issue is the arp request being sent back to R2 when R1 arps out simply because the arp request from R1 should have the source mac-address of R1's interface and as this is all L2 then the 2511 will send the arp reply to R1. At least it should do as you say all links are forwarding ie. there is no blocking.
R2 only becomes relevant when the destination is not on the same vlan because packets then need to be sent to the HSRP active gateway.
I'm not familiar with Alcatel but is the port connected to the 3750 configured any differently than the port connected directly to the 2511 ?
You say there is no blocking because there is no STP but what stops L2 loops in this network ? Whatever it is i would look there first.
Jon
Nicolas,
Can you share config of a 2511 router, 3750 and vlan info on these(If vlans are configured)
It seems to be a layer 2 issue.
Question1:
(I believe all switches 3750,2511,Alcatels are in one subnet)
Have you configured ip default-gateway 64.59.159.225 on all 2511 routers?
Question 2:
Also if that is the case and correct me if i am wrong the traffic flow when you are taking console is....
Forward Pathof Console:
Packet Enters on R1 -> Alcatel Switches -> 3750 -> 2511
Reverse Path:
2511 -> 3750 -> Alcatel Switches -> R2 -> 'X'
Now the packet has to go to R1 for reverse path reachability ,right??
Also please elaborate on packet flow from this point.
Do u have Direct connectivity between R1 and R2?
Ameya
CCNP
Hi Ameya,
I really think this is a problem with the 3750.  Reason being is that when I take it out of the picture, I have no problems.  The routers do have a direct connection between one another.
The switches here (3750, Alcatel) are on the same layer 2 network.  They are unaware of the subnet.  All of my routing happens on the CRS's.
Another thing to note is... if I keep all cfgs the same and clear arp on the 2511s, it works until the arp time-out occurs on the routers.  I see this on the router after the timeout
R2_#show arp | i 64.59.159.233
64.59.159.233   -          0000.0000.0000  Deleted    ARPA  TenGigE0/3/0/2.1
2511#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  64.59.159.230          47   000f.2349.e5c2  ARPA   Ethernet0
Internet  64.59.159.225           0   0000.0c07.ac0f  ARPA   Ethernet0
Internet  64.59.159.226           0   5475.d023.9a12  ARPA   Ethernet0
Internet  64.59.159.227           0   5475.d024.1a12  ARPA   Ethernet0
Internet  64.59.159.233           -   00b0.64fd.2bf7  ARPA   Ethernet0
Internet  64.59.159.234           9   0013.5f06.6024  ARPA   Ethernet0
Internet  64.59.159.235          47   00b0.64fd.216d  ARPA   Ethernet0
2511#ping 64.59.159.225
Sending 5, 100-byte ICMP Echos to 64.59.159.225, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Nicholas
As i said with arp the HSRP active gateway is largely irrelevant.
Is there anything special configured on the 3750 ?
What about the Alcatel switch that the 3750 connects to ?
Jon
the port connecting to mpls is setup in a port channel as such:
3750#
interface GigabitEthernet1/0/1
switchport mode trunk
speed nonegotiate
channel-group 1 mode active
end
interface Port-channel1
speed nonegotiate
end
To  answer this question: "You say there is no blocking because there is no  STP but what stops L2  loops in this network ? Whatever it is i would  look there first."
Our MPLS switches have their own built in redundancy  to accomidate for looping.  the vlan for this layer 2 circuit doesn't  seem to be looped.  The same layer 2 circuit is used when I plug my  network console direct to the mpls bypassing the 3750 and it works.
Is there anything on the 3750 that I should check?
Thanks for the info on the active gateway Jon, I was getting a little confused by that.
Nicholas
Perhaps you can post the 3750 config ?
It may come down to capturing packets ie. removing the arp entry on R1 for one of the 2511 and then pinging from R1 and spanning a port on the 3750 to a device running wireshark to see exactly what is happening with the packets.
Jon
Current configuration : 17642 bytes
! Last configuration change at 11:43:11 PDT Fri Aug 26 2011 by npace
! NVRAM config last updated at 11:43:14 PDT Fri Aug 26 2011 by npace
version 12.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service unsupported-transceiver
hostname switch3750
boot-start-marker
boot-end-marker
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxxxxx
username admin privilege 15 password 7 xxxxxxxxxxxxxxxxxxxxxx
username user password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login local-login local
aaa authorization exec default group tacacs+ local
aaa authorization exec login-local local
aaa authorization commands 0 default group tacacs+ local if-authenticated
aaa authorization commands 1 default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
switch 1 provision ws-c3750-48ts
system mtu routing 1500
vtp domain WAMU_1
vtp mode transparent
authentication mac-move permit
ip subnet-zero
no ip domain-lookup
ip domain-name mgmt.mlb.inet
crypto pki trustpoint TP-self-signed-592045440
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-592045440
revocation-check none
rsakeypair TP-self-signed-592045440
crypto pki certificate chain TP-self-signed-592045440
certificate self-signed 01
  3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35393230 34353434 30301E17 0D313130 32303731 39343533
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3539 32303435
  34343030 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  B72FA97D E0FBCA50 0F6649D5 E280BFA4 B9A98004 B0D630C6 EC2E9D21 16B7EA76
  F01B1B1D C2CB260F 6A74437C A15953E8 465092C6 FAAE8837 30E68AF4 DEE791E2
  1F2B44E4 71B9DD5E 2249C6E5 B854B8A8 9708CD30 43B22F5E B802F676 98A83309
  64CF1303 99B2D0EB C958C80C F426EF95 27AEE5B9 D5F898F0 B20D23D7 4E34B3D3
  02030100 01A37830 76300F06 03551D13 0101FF04 05300301 01FF3023 0603551D
  11041C30 1A821873 776D312E 616E2E76 632E6D67 6D742E6D 6C622E69 6E657430
  1F060355 1D230418 30168014 4EA71434 9F4DA1CD BECD656A DC4A70DE 0D360551
  301D0603 551D0E04 1604144E A714349F 4DA1CDBE CD656ADC 4A70DE0D 36055130
  0D06092A 864886F7 0D010104 05000381 81008048 A9AEB618 FDB55A22 9A398811
  32456FB9 9E876412 9151C5CD 8D56D6F0 ADDADCEE B39C4EA3 FF27C30D DDF9C5DE
  E40ED928 EE49913D 829DA3AC 9CE9DB04 A2E83697 B14BAFBB B65ADFAC 7A1B5760
  BACEA05E B58AF3EC 301341DC 7DBF22CC 87367A68 5D18C93D 2D6ACD6E 03A7CE23
  BEA0ED76 FA56E545 01D1A2EB FB6E2A34 A280
  quit
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
no spanning-tree vlan 1-4094
vlan internal allocation policy ascending
vlan 7
vlan 207
vlan 433
vlan 447
vlan 531
vlan 532
C
vlan 867
vlan 900
vlan 1443
speed nonegotiate
interface FastEthernet1/0/1
switchport access vlan 867
switchport mode access
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
d
speed 10
duplex half
interface FastEthernet1/0/14
speed 10
duplex half
interface FastEthernet1/0/15
switchport access vlan 531
speed 100
duplex full
interface FastEthernet1/0/16
speed 100
duplex full
interface FastEthernet1/0/17
speed 100
duplex full
interface FastEthernet1/0/18
speed 100
duplex full
interface FastEthernet1/0/19
speed 100
duplex full
interface FastEthernet1/0/20
speed 100
duplex full
interface FastEthernet1/0/21
speed 100
duplex full
interface FastEthernet1/0/22
speed 100
duplex full
interface FastEthernet1/0/23
switchport access vlan 532
speed 100
duplex full
interface FastEthernet1/0/24
switchport access vlan 7
speed 10
duplex half
interface FastEthernet1/0/25
speed 100
duplex full
interface FastEthernet1/0/26
speed 100
duplex full
interface FastEthernet1/0/27
speed 10
duplex half
interface FastEthernet1/0/28
speed 100
duplex full
interface FastEthernet1/0/29
speed 100
duplex full
interface FastEthernet1/0/30
switchport access vlan 447
speed 10
duplex half
interface FastEthernet1/0/31
speed 10
duplex half
interface FastEthernet1/0/32
speed 10
duplex half
interface FastEthernet1/0/33
speed 10
duplex half
interface FastEthernet1/0/34
switchport access vlan 433
interface FastEthernet1/0/35
switchport access vlan 207
interface FastEthernet1/0/36
switchport access vlan 1443
speed 100
duplex full
interface FastEthernet1/0/37
speed 100
duplex full
interface FastEthernet1/0/38
speed 10
duplex full
interface FastEthernet1/0/39
speed 100
duplex full
interface FastEthernet1/0/40
speed 100
duplex full
interface FastEthernet1/0/41
speed 100
duplex full
interface FastEthernet1/0/42
speed 100
duplex full
interface FastEthernet1/0/43
speed 100
duplex full
interface FastEthernet1/0/44
speed 100
duplex full
interface FastEthernet1/0/45
speed 100
duplex full
interface FastEthernet1/0/46
speed 100
duplex full
interface FastEthernet1/0/47
speed 100
duplex full
interface FastEthernet1/0/48
switchport access vlan 900
description Gi1/0/1>mpls<<  | GE 2/2/16 >>
speed nonegotiate
interface GigabitEthernet1/0/2
description Gi1/0/2>mplm1an.vc>
speed nonegotiate
interface GigabitEthernet1/0/3
shutdown
interface GigabitEthernet1/0/4
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan7
ip address 172.21.55.201 255.255.255.0
interface Vlan447
no ip address
ip default-gateway 172.21.55.1
ip classless
no ip http server
ip http secure-server
ip tacacs source-interface Vlan7
ip sla enable reaction-alerts
logging facility local2
logging 10.63.113.254
no cdp run
line con 0
login authentication local-login
line vty 5 15
ntp clock-period 36028861
ntp server 172.21.112.59
ntp server 172.21.16.59
end
Nicholas
There is nothing obvious in the switch config. As it is acting purely as L2 and there are no redundant links i'm not convinced the issue is with the switch.
I think you are going to have to span the trunk port and see what happens when you try and ping from R1 after clearing the arp cache for one of the 2511 devices.
Jon
Hi Jon,
What if we enable cdp on 2511 and 3750 and test traceroute mac from 2511,will it will help the cause??
We can check those frames on wireshark.
Ameya
Ameya
My understanding of the problem is not actually with the 2511 but with the CRS router R1. The mac-address times out and then when it arps again the request does not get back to R1 for some reason.
I think we need to understand what happens to the arp request at the 3750/2511.
Jon
Yup I agree with ya Jon.  Thanks to both of you for helping out here.  I will follow up on this thread when I have a chance to capture packets.
Thanks again
