10-10-2006 01:08 PM - edited 03-05-2019 12:10 PM
Hello. We have a 7206 (IOS 12.3) with an OC3 ATM circuit with multiple subinterfaces. The question is, if an ACL is bound to one incoming subinterface (our internet interface), will it be bound to all of the subinterfaces on the ATM circuit? If so, is there an alternate solution to this? Thanks
Solved! Go to Solution.
10-10-2006 03:49 PM
Patrick
If you assign/bind an ACL to a subinterface it works on that particular subinterface and not on all the subinterfaces.
Rick
10-10-2006 03:49 PM
Patrick
Rick
