auditing traffic inside a vlan
danenewman
Hello. I want to audit traffic inside of a vlan so it will tell me when one host communicates to another host and what protocol it used without configuring spans on every port and putting a sniffer there.
I was thinking maybe I could log on a mac access-list but I can't
Switch(config-ext-macl)#permit any any ?
<0-65535> An arbitrary EtherType in decimal, hex, or octal
aarp EtherType: AppleTalk ARP
amber EtherType: DEC-Amber
appletalk EtherType: AppleTalk/EtherTalk
cos CoS value
dec-spanning EtherType: DEC-Spanning-Tree
decnet-iv EtherType: DECnet Phase IV
diagnostic EtherType: DEC-Diagnostic
dsm EtherType: DEC-DSM
etype-6000 EtherType: 0x6000
etype-8042 EtherType: 0x8042
lat EtherType: DEC-LAT
lavc-sca EtherType: DEC-LAVC-SCA
lsap LSAP value
mop-console EtherType: DEC-MOP Remote Console
mop-dump EtherType: DEC-MOP Dump
msdos EtherType: DEC-MSDOS
mumps EtherType: DEC-MUMPS
netbios EtherType: DEC-NETBIOS
vines-echo EtherType: VINES Echo
vines-ip EtherType: VINES IP
xns-idp EtherType: XNS IDP
<cr>
Or
I could configure a vlan access-map with a ACL that logged but I can't
Switch(config-access-map)#match ip add 104
% Logging ACLs are not supported.
Is there anyway to do this?
chschroe
I couldn't possibly imagine a way to do that.
The device does build tables of what mac addresses are out what interfaces, but that is about it... tracking all L2 flows would be very, very stressful to say the least.
What sort of platform is it?
NS
