Auto-created Tunnel interfaces on Sup2T
michacox
I recently migrated from a Cat6k Sup720 running s72033-advipservicesk9_wan-mz.122-33.SXI3.bin to a Sup2T running s2t54-adventerprisek9-mz.SPA.150-1.SY1.bin. The config is basically the same, but on the new Sup2T I'm getting 7 Tunnel interfaces which are being created automatically, so to speak I guess. They aren't in the config. See below snippet from the show ip int brief output.
Tunnel0                10.30.2.98      YES unset  up                    up
Tunnel1                10.30.2.98      YES unset  up                    up
Tunnel2                10.30.2.98      YES unset  up                    up
Tunnel3                10.30.2.98      YES unset  up                    up
Tunnel4                10.30.2.98      YES unset  up                    up
Tunnel5                10.30.2.98      YES unset  up                    up
Tunnel6                10.30.2.98      YES unset  up                    up
The address they all use is the Gig port that is the link to the WAN router (routed OSPF), below.
interface GigabitEthernet2/1
description WAN edge
ip address 10.30.2.98 255.255.255.248
no ip redirects
no ip proxy-arp
ip flow monitor Netflow-Monitor-1 input
ip pim query-interval 1
ip pim sparse-mode
ip ospf network point-to-point
ip ospf hello-interval 1
flowcontrol receive desired
Is anyone aware of what process or feature might be creating these interfaces? They don't appear to affect performance or functionality, but I am curious why they are there and where they came from since this behavior isn't seen on the old Sup720. Thanks.
Michael
2 Accepted Solutions
Peter Paluch
Hi Michael,
I believe these tunnels are related to the PIM Sparse Mode operation and they probably represent a PIM-Register tunnel used during the multicast source registration process. I have no firm proof of that but I have also seen these tunnels being created on the fly on software ISR router platforms on recent IOSes when PIM-SM was run.
Would it actually be possible to elicit any output from show run int tun0 up to show run int tun6 (yes, I know they are not in the config but sometimes this command works for dynamically configured interfaces, too)? Or at least show interface tun0 and show ip interface tun0?
Best regards,
Peter
Hi Michael,
Peter is absolutely correct. These tunnels are created automatically by the Multicast Forwarding Information Base (MFIB) as part of the PIM sparse-mode registration process.
From the IPv4 Multicast Layer 3 Features section of the Catalyst 6500 Software Configuration Guide:
The PIM-SM protocol requires the first-hop router for a multicast source to send a register packet to the Rendezvous Point (RP) when the source starts sending packets. On the Supervisor Engine 2T, the PIM control-plane uses the MFIB infrastructure to represent the PIM register tunnel as an interfaceand adds it to the outgoing interface list when PIM register packets are sent. When a new PIM RP is configured or learned, a PIM register tunnel interface is created and used for PIM register packets. The interface is deleted when a register-stop packet is received. On the RP, an additional interface is created and used to decapsulate the PIM register packet when it is received.
You can see the tunnels created and the groups associated with those tunnels using the show ip pim tunnel command.
Peter Paluch
Hi Michael,
Best regards,
Peter
Hi Michael,
Thanks to both of you.
Yes, the show ip pim tunnel output does show the PIM-related tunnels:
#sh ip pim tunnel
Tunnel0
  Type  : PIM Encap
  RP    : 10.28.254.253
  Source: 10.30.2.98
Tunnel1
  Type  : PIM Encap
  RP    : 10.28.254.254
  Source: 10.30.2.98
The show run int tun0 command only produces:
#sh run int tun0
Building configuration...
Current configuration : 5 bytes
end
However, the show int does indeed show some valid output though:
#sh int tun0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Interface is unnumbered. Using address of GigabitEthernet2/1 (10.30.2.98)
  MTU 17864 bytes, BW 100 Kbit, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.30.2.98 (GigabitEthernet2/1), destination 10.28.254.253
   Tunnel Subblocks:
      src-track:
         Tunnel0 source tracking subblock associated with GigabitEthernet2/1
          Set of tunnels with source GigabitEthernet2/1, 7 members (includes iterators), on interface
  Tunnel protocol/transport PIM/IPv4
  Tunnel TOS/Traffic Class 0xC0,  Tunnel TTL 255
  Tunnel transport MTU 1472 bytes
  Tunnel is transmit only
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input never, output never, output hang never
Good to know!
Michael
You can use the "show derived-config interface tunnel #" to get the interface derived configuration:
Router#show derived-config interface tunnel 1
Derived configuration : 199 bytes
interface Tunnel1
description Pim Register Tunnel (Encap) for RP x.x.x.x
ip unnumbered Vlanxxx
tunnel source Vlanxxx
tunnel destination x.x.x.x
tunnel tos 192
no routing dynamic
end
Best regards.
