Auto QOS
shijuuu
The Auto qos doesnt work under gigaethernet on 2821, on serial its work fine...
any solution for this ?
thanks
Peter Paluch
Would you mind pasting the transcript of the console messages that appear when you try to apply the AutoQOS on a GigE interface? Or perhaps being more detailed? Saying just "it doesn't work" does not tell us anything about the real cause of your problem and it's hard to help you in such case.
Best regards,
Peter
love4u.pratik
Auto Qos is not available on gigabit ethernet interface for cisco 2821. It may work fine on fastehernet interfaces, serial, PVC, ATM but its auto qos is not available on gigabit ethernet interfaces.
Go through this link may be it will help...
http://www.cisco.com/en/US/technologies/tk543/tk879/technologies_qas0900aecd8020a589_ps6613_Products_Q_and_A_Item.html
