Autocommand and SSH
brobinson
Hello -
I am configuring autocommand with SSH, but it does not work. I put the username with the "autocommand" option to execute a "menu [menu name]".
It works fine on telnet. There is no configuration on the line.
Please advise if the autocommand option in the username is compatible with SSH.
Thanks!!!
tstanik
Level 5
Level 5
To automatically execute a command when a user connects to a particular line, use the "AUTOCOMMAND" command in line configuration mode. To disable the automatic execution, use the no form of this command.
For more information on using this command refer the following URL:
http://www.cisco.com/en/US/docs/ios/12_3/termserv/command/reference/ter_a1g.html#wp998780
