switches that can do layer 3
jason-calbert_2
Level 3
Level 3
Can you please let me know if the 29XX or the 35XX can do layer 3 routing. Specifically the 3550 or 2950. Thanks
Collin Clark
2950 no, but the 3550 can with the Advanced IP image.
Hope that helps.
Collin Clark
Hope that helps.
Can you tell me if any other switches can run layer 3 with the correct IOS. Thanks
Jason
Jason
3550, 3560, 3750
4948
4500
6500
Jon
Jon Marshall
Jason
2950 - No, it is layer 2 only.
3550 - yes this is a layer 3 switch. The base image supports static routing + RIP. The advanced image supports EIGRP/OSPF etc.
Jon
