Autoconf for Cisco ATAs
Robert Saurer
What is the Cisco recommended way of using Autoconf for Cisco ATAs (187,188,190)?
1) It seems that there are no unique OUIs for older ATA models. (Cisco ATA OUIs seem to be shared with Cisco Phones)
It seems that "OUI 34DBFD is only used for ATA 190" or the other way round "all ATA 190 boxes have OUI 34DBFD". Correct?
2) The ATA 190 pops up as "Cisco-Switch" in Device Classifier:
Switch#show device classifier attached interface g1/0/1 detail
DC default profile file version supported = 1
Detail:
Protocol:  C - CDP  L - LLDP  D - DHCP  M - OUI  H - HTTP  S - SIP  T - H323  N - MDNS
MAC_Address     Port_Id    Cert Parent Protocol         ProfileType  Profile Name                        Device_Name
34db.fd18.f37f  Gi1/0/1     20    1    C     M          Default      Cisco-Switch                        Cisco ATA 190
I don't want to configure Autoconf for device-type regex "Cisco-Switch" because then it would also trigger when I connect a Cisco switch:
conf t
template ATA_INTERFACE_TEMPLATE
description *** ATA ***
spanning-tree portfast edge
 spanning-tree bpduguard enable
 switchport access vlan 10
 switchport mode access
 switchport nonegotiate
 switchport block unicast
 switchport port-security
 storm-control broadcast level pps 1k
 storm-control multicast level pps 2k
 storm-control action shutdown
 storm-control action trap
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 mls qos trust dscp
parameter-map type subscriber attribute-to-service BUILTIN_DEVICE_TO_TEMPLATE
110 map device-type regex "Cisco-Switch"
  10 interface-template ATA_INTERFACE_TEMPLATE
end
And so far I found no way with Autoconf to look for the DC Device-name instead of the DC Profile-name.
I also found no way yet to reprogram Device Classifier to detect the ATA 190 as Profile Name "Cisco ATA"
Any ideas?
Same applies for Cisco Video Conferencing stations (CTS-.*)
Auto Smartports work like a charm (macro auto trigger CISCO_ATA_EVENT, device Cisco ATA 190) because there I can match the CDP Plattform with the "device" command. But we don't want the config changes whenever there is a linkup/linkdown event or someone connects an ATA.
I tried with 15.2(2)E4 and 15.2(4)E1.
0 Replies 0
