AutoQOS sanity check
wwwillster07
switch#show auto qos
AutoQoS not enabled on any interface
That means this config is inconsequential and not used, correct?
class-map match-all AutoQos-4.0-Scavenger-Classify
match access-group name AutoQos-4.0-ACL-Scavenger
class-map match-all AutoQos-4.0-Signaling-Classify
match access-group name AutoQos-4.0-ACL-Signaling
class-map match-any AutoQos-4.0-Priority-Queue
match cos 5
match dscp ef
match dscp cs5
match dscp cs4
class-map match-all AutoQos-4.0-VoIP-Data-Cos
match cos 5
class-map match-any AutoQos-4.0-Multimedia-Stream-Queue
match dscp af31
match dscp af32
match dscp af33
class-map match-all AutoQos-4.0-Network-Mgmt
match dscp cs2
class-map match-all AutoQos-4.0-VoIP-Signal-Cos
match cos 3
class-map match-any AutoQos-4.0-Multimedia-Conf-Queue
match cos 4
match dscp af41
match dscp af42
match dscp af43
match access-group name AutoQos-4.0-ACL-Multimedia-Conf
class-map match-any AutoQos-4.0-Transaction-Data
match dscp af21
match dscp af22
match dscp af23
class-map match-all AutoQos-4.0-Network-Ctrl
match dscp cs7
match dscp cs1
class-map match-all AutoQos-4.0-Default-Classify
match access-group name AutoQos-4.0-ACL-Default
class-map match-any AutoQos-4.0-Signaling
match dscp cs3
match cos 3
class-map match-any AutoQos-4.0-Bulk-Data-Queue
match cos 1
match dscp af11
match dscp af12
match dscp af13
match access-group name AutoQos-4.0-ACL-Bulk-Data
class-map match-all AutoQos-4.0-Transaction-Classify
match access-group name AutoQos-4.0-ACL-Transactional-Data
class-map match-all VOIP_Bearer_Cmap
match dscp ef
class-map match-any Network_Sig_Ctrl_Cmap
match dscp cs6
match dscp cs7
match dscp cs3
class-map match-all AutoQos-4.0-Broadcast-Vid
match dscp cs5
match dscp af11
match dscp af12
match dscp af13
class-map match-any AutoQos-4.0-Scavenger-Queue
match dscp cs1
match cos 1
class-map match-any AutoQos-4.0-VoIP
match dscp ef
match cos 5
match dscp af41
match dscp af42
match dscp af43
class-map match-any AutoQos-4.0-Control-Mgmt-Queue
match cos 3
match dscp cs7
match dscp cs6
match dscp cs3
match dscp cs2
class-map match-all AutoQos-4.0-Bulk-Data-Classify
class-map match-any AutoQos-4.0-Trans-Data-Queue
match cos 2
match dscp af21
match dscp af22
match dscp af23
match dscp af31
match dscp af32
match dscp af33
class-map match-any AutoQos-4.0-VoIP-Data
match dscp ef
match cos 5
class-map match-all AutoQos-4.0-Internetwork-Ctrl
match dscp cs6
class-map match-all AutoQos-4.0-Realtime-Interact
match dscp cs4
class-map match-all AutoQos-4.0-Multimedia-Conf-Classify
class-map match-any AutoQos-4.0-VoIP-Signal
match dscp cs3
match cos 3
end
2 Accepted Solutions
Joseph W. Doherty
"switch#show auto qos
That means this config is inconsequential and not used, correct?"
Unsure.  Might just mean AutoQoS might not be configured on any interface but possibly service policies, using AutoQoS statements might be present on interfaces.
BTW see if you can do the following command:
sh run | inc interface|service-policy
If you can, it might be informative.
Joseph W. Doherty
