02-06-2012 04:27 PM - edited 03-07-2019 04:45 AM
I see there is a Aux power port on the back. Is there a power supply for a CISCO CATALYST 3560C PD 8PORT PSE to power it from a 110 VAC wall outlet or is only able to be powered through POE?
02-06-2012 06:10 PM
Yes, you need to use the supplied AC power cord to connect the AC power connector to an AC power outlet.
02-06-2012 06:17 PM
There was not a power cord supplied. It said it was sold separately but I can't find the part number.
02-06-2012 06:22 PM
It should comes in the box with the switch, if not you can ask your sales guy to provided to you. There should be no cost to you.
02-06-2012 06:32 PM
No the manual says it is either powered over Ethernet or using a power adapter sold separately but it doesn't give a part number.
02-06-2012 07:21 PM
These items ship with the Catalyst 3560 8- and 12-port switches:
see this link:
