backing up flash
saidfrh18
i am trying to back up the IOs to a TFTp server. I can ping the TFTP server. When entering command copy flash TFTP, the address of the remote host is entered; immediately the Destination filename is followed, not the Sourcefilename.  see below.  Any sugestions would be appreciated.
RouterA#copy flash tftp
Address or name of remote host []? 172.16.30.2
Destination filename [flash]? c2500-i-l.121-3.bin
%Error opening flash:1:flash (No such file or directory)
RouterA#
RouterA#sh ver
IOS (tm) 2500 Software (C2500-I-L), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 06-Jul-00 07:33 by cmong
Image text-base: 0x0303E710, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
RouterA uptime is 2 minutes
System returned to ROM by reload
System image file is "flash:c2500-i-l.121-3.bin"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 06160672, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash partition 1 (Read ONLY)
8192K bytes of processor board System flash partition 2 (Read/Write)
Ganesh Hariharan
RouterA#
RouterA#sh ver
Bridging software.
Just try the following to copy the flash to tftp:-
Router#sh flash
Directory of flash:/
2 -rwx 99 Feb 24 2005 11:16:03 -05:00 private-config.text
3 -rwx 8149 Feb 24 2005 11:16:03 -05:00 config.text
6 -rwx 342 Jun 10 2004 11:36:32 -04:00 system_env_vars
24 drwx 192 Jun 10 2004 11:36:23 -04:00 c2500-i5q3l2-mz.121-20.EA2
7 -rwx 18 Jun 10 2004 11:36:32 -04:00 env_vars
15998976 bytes total (8269312 bytes free)
c2500-i5q3l2-mz.121-20.EA2 is the directory that the IOS file is in
This gives you the IOS file name in the directory
Router#cd flash:/c2500-i5q3l2-mz.121-20.EA2
Router#sh flash
Directory of flash:/c2500-i5q3l2-mz.121-20.EA2/
25 drwx 2688 Jun 10 2004 11:34:50 -04:00 html
107 -rwx 4219426 Jun 10 2004 11:36:23 -04:00 c2500-i5q3l2-mz.121-20.EA2.bin
108 -rwx 252 Jun 10 2004 11:36:23 -04:00 info
Next copy the IOS to the tftp server
Router#copy flash tftp
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Leo Laohoo
Try to use the command copy flash:c2500-i-l.121-3.bin tftp://flash:c2500-i-l.121-3.bin/c2500-i-l.121-3.bin
Ganesh Hariharan
RouterA#
RouterA#sh ver
Bridging software.
Router#sh flash
Router#sh flash
Hope to Help !!
Ganesh.H
