BACKUP WAN USING SWITCHES AND LAN-EXTENSION
CCDECCDE9
I am trying to implement redundancy between two sites using LAN-EXTENSION from two different Service Providers.The following is the configuration and I want FAILOVER to happen automatically WITH TWO LINKS PLUGGED IN ALL THE TIME .
When I plugin both the links I am not able to connect to SITE A from
SITE B or Vice Versa with the following configuration.IF I SHUTDOWN BACKUP LINK or PRIMARY LINK on SITE B everything is working.Please Advise.Right now I have shutdown interface FastEthernet0/48 on 3550-SITE B and everything seems to be good but I want this interface FastEthernet0/48 on 3550-SITE B to be UNSHUT AND STILL EVERYTHING SHOULD BE WORKING
4006-SITE A#
interface FastEthernet2/43---------------------primary Service provider A
description primary-LAN-X
switchport access vlan 24
switchport mode access
speed 100
duplex full
end
interface FastEthernet3/12---------------------backup Service Provider B
description BACKUP-LAN-X
speed 100
duplex full
end
interface Vlan24
ip address 10.32.0.7 255.255.252.0
ip route 0.0.0.0 0.0.0.0 10.32.0.5
ip route 10.32.64.0 255.255.252.0 10.32.0.1
ip route 10.32.72.0 255.255.254.0 10.32.0.1
3750-SITE B:
interface GigabitEthernet1/0/1---------------cross over connection to 3550-SITE B:interface FastEthernet0/1
power inline never
interface Vlan1
ip address 10.32.0.1 255.255.252.0
3550-SITE B:
interface FastEthernet0/1---------------------cross over connection to 3750-SITE B:interface FastEthernet0/1
no ip address
duplex full
speed 100
interface FastEthernet0/47------------------primary Service provider A
description to SERVICE POVIDER A
no ip address
duplex full
speed 100
end
interface FastEthernet0/48-----------------backup Service Provider B
description to SERVICE POVIDER B
no ip address
duplex full
speed 100
end
interface Vlan1
ip address 10.32.0.10 255.255.252.0
no ip route-cache
ip default-gateway 10.32.0.1
CCDECCDE9
diagram attached
