Bandwidth Limit per VLAN
stephen.stack
Level 9
Level 9
Hi Experts,
I have been given the task o designing a network for a managed/serviced office environment. We will have a 5Mb dedicated link or so from our local ISP. IP addresses will not be an issue for me. However, the entire office will service 30 or so clients with about 1 to 5 users per client.
I will be using VLANs to seperate client traffic. I have been asked to provide a solution to manage bandwidth per client.
So, i suppose i would like to be able to allow one client a dedicated 1MB etc... and the rest share bandwidth.
Does anyone have ideas on how i can achieve bandwitdh shaping per vlan?
Thanks and regards
stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
bjornarsb
Level 9
Level 9
QOS with cos values at layer 2,
and mapping to layer 3 creating a service policy.
If you just want to shape pr vlan it can be done at your layer 3 device.
BR,
Bjornarsb
Hi Bjornarsb,
Thanks for the info. I think i know what you mean, But would you have any specific examples. Any more ideas welcome too 🙂
Stephen
OK, here is maybe a start:
Distribution Switch connected to the Access-layer:
class-map videoclass
match cos 7
policy-map videopolicy
class videoclass
set ip dscp 56
police 5000000 2000000 exceed-action drop
interface gigabitethernet0/1
service-policy input videopolicy
Default DSCP-to-CoS map has DSCP values 56 to 63 mapped to CoS value 7,
show class-map videoclass
show policy-map videopolicy
show mls qos maps [cos-dscp | dscp-cos]
Router:
Router(config)# class-map match-all gold-data
Router(config-cmap)# match ip dscp 40
Router(config-cmap)# exit
Router(config)# class-map match-all bronze-data
Router(config-cmap)# match ip dscp 8
Router(config)# policy-map policy1
Router(config-pmap)# class gold-data
Router(config-pmap-c)# shape average 2000000
Router(config-pmap-c)# exit
Router(config-pmap)# class bronze-data
Router(config-pmap-c)# shape average 5000000
Router(config-pmap)# class class-default
Router(config-pmap-c)# shape average 3000000
Router(config-pmap)# exit
Router(config)#
Router(config)# interface WAN
Router(config-if)# service-policy output policy1
Router(config-if)# exit
HTH, do not hesitate to ask if you need more help.
For more explenations , please have a look at this example:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ewa/configuration/guide/qos.html#wp1223587
BR,
Bjornarsb
