Bandwidth Restriction
praveen77
Community Member
I am using Cisco 1841 Router which has a 512kbps line on serial interface. The users are connected to Fa 0/0 & 0/1. Now i need to restrict the bandwidth of one of my ports to 20kbps. How to achieve this?
pkhatri
Level 11
Level 11
Praveen,
To restrict all traffic on FastEthernet0/1 to 20Mpbs, you could use something like the following:
policy-map Policer20M
class class-default
police 20000000
interface FastEthernet0/1
service-policy input Policer20M
service-policy output Policer20M
Pls do remember to rate posts.
Paresh
I wonder if putting the policy-map on one of the FastEthernet interfaces would actually restrict the bandwidth between both FastEthernet interfaces as well, that is, limiting the bandwidth between users on FastEthernet0/0 and FastEthernet0/1. Also, do you want 20Kbps or 20Mbps ? You might want to try and put the policy map on the serial interface instead as following (this would restrict the bandwidth to 20Kbps for users connected to FastEthernet0/0 with subnet 192.168.1.0/24):
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
class-map FE0
match ip address 101
policy-map police20K
class FE0
police 20000
interface Serial0/0
service-policy input police20K
service-policy output police20K
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip any 192.168.1.0 0.0.0.255
Nethelper
