Basic configuration, webinterface
AF_A403943
Community Member
Hey
I have tried a couple of days to connect to my cisco 2504 Wireless Controllers. I can connect to it through serial communication
I have assign an IP address and I have enable the webmode, what more shall I do?
It answers neither to ping or web communication
Here are two commands from CLI.
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 44:03:a7:31:83:a0
IP Address....................................... 10.19.0.2
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.19.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 1
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.19.0.3
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
(Cisco Controller) >show network summary
RF-Network Name............................. rfggr40
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
AF_A403943
Community Member
Problem solved
Management interface is on port 1, therefore I need to conect my computer to port 1 on the controller
And now its dead again
You can't ping it anymore ?
Alain
It's going up and it's going down. The only way to reset the unit after it's going down is to do a factory reset
I havent figure out what I do wrong when its going down.
