Basic DNS question
Bagley5777
Frequent Visitor
Frequent Visitor
I need some help with this question (below) please- I understand the answer is "b" and DNS can prevent browsing of webpages if configured incorrectly, but so can having the wrong default gateway.  What specifically alludes to a DNS server address error here over a default gateway server address error- does it have something to do with the suffix issues?  THANKS FOR YOUR HELP!!
A user cannot connect to any Web sites. Review the ipconfig results that follow and
select the best answer explaining why this has occurred.
Windows IP Configuration
Host Name ........................................... : Computer1
Primary Dns Suffix ................................. :
Node Type ............................................ : Hybrid
IP Routing Enabled................................ : No
WINS Proxy Enabled ............................... : No
Ethernet adapter lan:
Connection-specific DNS Suffix.:
Description ........................................... : Intel(R)
82566DC-2 Gigabit Network Connection
Physical Address ................................... : 00-1C-C0-A1-55-16
DHCP Enabled ....................................... : No
Autoconfiguration Enabled ..................... : Yes
IPv4 Address ........................................ : 10.254.254.105(Preferred)
Subnet Mask ......................................... : 255.255.255.0
Default Gateway .................................... : 10.254.254.1
DNS Servers .......................................... : 10.255.254.1
a. The MAC address is incorrect.
b. The DNS server address is incorrect.
c. The default gateway address is incorrect.
d. The computer has no IP address.
chrihussey
Understand your question and you raise a valid point regarding the default gateway. However, with the knowledge that the answer is "B", the following rational would apply:
A - Mac address: Short of configuring an invalid MAC, (broadcast, multicast, etc), it can be almost anything so not the issue here.
C- If the problem is stated as being unable to browse, it indicates then that perhaps other things work and that it wouldn't necessarily be a default gateway issue. It is a valid IP on the proper subnet too.
D - The computer obviously has an IP address
B- Browsing is dependent on DNS, so again if it is the specific problem and other things are working then it would point to the DNS.
Hope this helps
chrihussey
Hope this helps
