beginner question
EdmondsHOF
Community Member
How can a user with an IP address not part of the subnet for his default gateway (because a user is in a VLAN far away from others in his VLAN), be allowed or be able to work properly?
dabels
Level 3
Level 3
you will have to bridge that vlan to where this user is or put him in the different subnet that is there with the default gateway to allow him to work.
Giuseppe Larosa
Hello Edmond,
in addition to what suggested in the previous a network can support mobile users using IP mobile
see for example
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htmultun.html
the local router has to build a tunnel to the natural default gateway so that the user can pretend to be still in its subnet
Hope to help
Giuseppe
