05-03-2007 07:17 AM - edited 03-05-2019 03:50 PM
Imagine I need to document and draw a topology diagram (related to layer 1-3) of an existing data center.
What approach do you use to perform such documentation? Do you go physically router by router (or switch by switch) to determine neighbor information with CDP neighbor command for example?
Assume I have no existing diagram for such network.
Once I get a picture of how the current environment is setup, I am planning to show this to a Cisco rep and discuss upgrade options.
Please let me know what you think.
Solved! Go to Solution.
05-09-2007 07:12 AM
Enable routing protocol. Also CDP neighbor and trace route command is a good option. If yours network is small you can also do manually.
05-09-2007 07:12 AM
