Best Practice Step to Layer 2 Configurations.
Ahmed Ashfaque
Good Day,
Guys please advice on steps in order to configure layer 2 networks . For example
1 - VTP Configs (in case if not nexus)
2 - Configurations of Vlans
3 - STP configuration with loadbalancing
4 - Port Security on edge switches.
Guys pls add your inputs....
Thanks & Regards,
Julio E. Moisa
My recommendations are:
     All the switches must be configured as Transparent, Is recommendable a good knowledge about VTP to be deployed because any human error could create critical problems on the network, other solution is to use VTP version 3 but you must see if it is supported on your switch models.
      Create VLAN manually and with real descriptions and on Capital Letters to be visible.
      Usually I dont suggest modify the STP parameters to manipulate the traffic but you can use same priority on the designated ports from the root switch toward the non root switches or you can modify the STP cost under the interfaces under the root ports toward the root switch.
     Configure a maximum amount of mac addresses, I think it could be 2 or 3 for users and meeting rooms at least 5, also configure the port security aging time to remove the inactive mac addresses: switchport port-security aging time <time in minutes> type inactivity. You can set up the port security as sticky and violation shutdown.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
if you wish to learn about these features then it would advisable to check out some Cisco documentation on each subject as it would to lengthy of a post to provide on here  - Julio has provided some good links but there is also  a vast amount of information readily availble on the Cisco CCO
However if you have a query/issue  on a particular feature then please elaborate and we would kindly try to assist
Res
paul
Kind Regards
Paul
