Best way of denying access to a VLAN port based on MAC address on Catalyst 4500
captkloss
We have couple of  catalyst 4500 chassis - all publicly (as in "office space") accessible ports are limited to a specific VLAN. We would like to deny "access" to all devices outside of a list of approved MAC addresses. What would be most efficient / "best practice" way of achieving this goal?
Hardware we use:  WS-C4510R+E running 03.04.02.SG
Thanks!
Rob Cluett
Dynamic ARP Inspection should accomplish what you're looking to do.  Here's a chapter from Cisco Press that acts as good overview:
http://www.ciscopress.com/articles/article.asp?p=1181682&seqNum=8
Correct me if i'm wrong, but from what i see DAI would not prevent someone from bringing a private laptop, plugging it into an available port in the office space and being able to browse the network.
Thanks!
If you are looking to lock down ports to their respective hosts mac address you can use port-security.  What you'll be doing is assigning the MAC address of a host to the port that it's connected to.  All other ports should be set into a shutdown state preventing an attacker from connecting to any port that doesn't have a host connected. See below:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-4SY/config_guide/sup6T/15_3_sy_swcg_6T/port_security.html?dtid=osscdc000283
The above port-security command will shutdown the interface if any host is attached that does not have fa16.3e23.8161 as it's MAC address.
