Best way to set default ospf route
kametolearn
Hello Cisco Community,
I'm sitting here trying to get my network running but because I don't know the right way to do this I'm just throwing different solutions at the problem to see which ones sticks.  Basically this is a network on ESXI behind my home router which is doing NAT translation and a VYOS router which is also doing nat translation.  The problem is that I don't know the best way to tell all routers in the network to use VYOS_NAT_ROUTER for reaching the internet.
OSPF is running between R1,R2,R3,R4, and CISCO_EDGE_ROUTER.  All the Cisco routers can reach each other.
I have used default-information originate always on R4 and have verified this default our is in the OSPF database on all neighbor routers.
My problem is that R4 can reach VYOS_NAT_ROUTER (10.10.10.1) but none of the others can reach it.
The default route in the OSPF database looks like this:
# show ip route
0*E2 0.0.0.0/0 [110/1] via 10.0.0.254
For reference the 10.0.0.254 is CISCO_EDGE_ROUTER
Attached is a map.
So the big question, how do I tell CISCO_EDGE_ROUTER to forward traffic to VYOS_NAT_ROUTER.
NETWORK
Philip D'Ath
Wouldn't a simple static route do the trick?
