between N5K and Nexus 9K port channel not coming up
lerner cisco
Hi All,
trying to configure port channel between Nexus 5k and Nexus 9K ,  port channel not coming up . the connected interfaces on the Nexus 5k device  status is suspended , Once I remove port channel configuration , interface status  moved from suspended to connected , any suggestion please ?
configs
interface port-channel300
   switchport mode trunk
  switchport trunk allowed vlan 300-314,703
  speed 10000   ( this got added automatically under the portchannel 300)
interface Ethernet1/3
  switchport trunk allowed vlan 300 - 314,703
  channel-group 300 mode active
interface Ethernet1/4
logs ---
nexus 5K# sh int port channel 300
port-channel300 is down (No operational members)
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/3, Eth1/4
nexus 5K# sh int eth1/3
Ethernet1/3 is down (suspended)
 Dedicated Interface
  Belongs to Po300
ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/3, operational Transmit Flow Control state changed to off
ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/4, operational Receive Flow Control state changed to off
Nexus 5k #sh int status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/3               xyz                 suspnd    trunk     full    10G     10Gbase-SR
Eth1/4               xyz                 suspnd    trunk     full    10G     10Gbase-SR
nexus 5k# sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
300   Po300(SD)   Eth      LACP      Eth1/3(s)    Eth1/4(s)
the moment remove int port channel 300 from the switch , ports status shows - connected instead of suspended
5 Replies 5
try and enable lacp:
nexus5K(config)# feature lacp
feature lacp already in place , disable and added again , still no luck :(
I am not sure if that makes a difference, but I usually explicitly include Vlan1 in the allowed list of Vlans (unless of course you have configured another Vlan as the native one).
thank you all your inputs , I will let you know once done , remote end nexus 9K customer supported , yet to get response from them . thanks again.
Reza Sharifi
Can you try this;
Completely delete po300 from both switches
no po300
also under interface 1/3 and 1/4 delete all these commands on both switches.
now rebuild po300 this way
interface Ethernet1/3 and 1/4
this command create po300.
now add these commands to the po interface and not the physical interfaces
int po300
no sh
At this time po300 should come up as well as interfaces 1/3 and 1/4 and also sync below commands to the physical interfaces
