BFD and OSPF on VLAN interface
texoruser
I'm tryng to enable BFD for OSPF on a SVI on a Catalyst 6509 Sup 720.
Even if the vlan interface accepts the configuration command "ip ospf bfd", no BFD neighborship is established and there is no way to set bfd intervals.
Has anybody encountered the same behaviour?
7 Replies 7
ariela
Level 4
Level 4
which version of IOS do you use?
Andrea
BDF is not supported on SVL
Well It's funny, look at this output:
Vlan305 is up, line protocol is up
Internet Address 10.119.200.2/24, Area 0
Process ID 100, Router ID 10.119.253.12, Network Type BROADCAST, Cost: 10
Transmit Delay is 1 sec, State BDR, Priority 1, BFD enabled
Designated Router (ID) 10.119.253.11, Interface address 10.119.200.3
Backup Designated router (ID) 10.119.253.12, Interface address 10.119.200.2
It says that BFD is enabled on the specific VLAN where we configured it but no matter this, no BFD neigborship is established.
Thanks in advance
Fausto
Hi Andrea,
we use:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXH1, RELEASE SOFTWARE (fc3)
regards
Fausto
Well,
it seems like a problem that I've found some weeks ago on SRB1. The BFD feature was configurable, but not effective. That bug maybe will be corrected on SRC. In your case, I don't know, but my advice is to check the Bug Toolkit, or open a case.
Just for me: SXH modular version?
Andrea
edit: uops .. I see now ... Have you got a 6500 or a 7600 device?
Hi Andrea,
we use mesh made of six 6509 in this hw configuration:
Mod Ports Card Type Model
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
2 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
7 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
8 6 Firewall Module WS-SVC-FWM-1
Fausto
Hmm ...
Try to upgrade to SXH2a.
Unfortunately I don't see a specific bug, but maybe is a DDTS bug internal only.
Please let me know
Andrea
