Showing results forĀ
Search instead forĀ
Did you mean:Ā
BFD on etherchannel running OSPF
maliha_fayyaz
we have  'WS-C6509-E' in core (VSS) connected through fiber and running OSPF on ether channel . I want to configure BFD but the option is not available under the interface port channel command. It is available under a single interface and ospf routing process command. The version running on switches are  Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.0(1)  RELEASE SOFTWARE (fc4).
Any suggestions why bfd option not available under ether channel interface
Pawan Raut
Level 4
Level 4
  • Port-channel configuration limitations are as follows:
    • For Layer 3 port channels used by BFD, you must enable Link Aggregation Control Protocol (LACP) on the port channel.
    • For Layer 2 port channels used by SVI sessions, you must enable LACP on the port channel.
  • BFD is supported on SVI interfaces that are formed over virtual port channels (vPCs), vPC peer-links and FabricPath links.
can we run bfd on interface vlan
