BGP Peer are not pinging
Haider Raza
I created topology in gns3 and running BGP and router R1 is able to ping R3 and R5 but not able to ping R4 fa0/0 interface .neighbor-ship established and all interfaces are configured correctly.
Please help me to get the reason.
R1 Config
interface Loopback100
ip address 10.5.1.1 255.255.0.0
interface FastEthernet0/0
ip address 10.2.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
router bgp 100
no synchronization
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.0
network 10.2.1.0 mask 255.255.255.0
network 172.16.1.0 mask 255.255.255.0
network 172.17.1.0 mask 255.255.255.0
neighbor 10.1.1.2 remote-as 100
neighbor 10.2.1.2 remote-as 100
no auto-summary
R2 Config
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
router bgp 100
no synchronization
neighbor 10.1.1.1 remote-as 100
neighbor 172.16.1.2 remote-as 900
no auto-summary
R3 Config
ip address 172.16.1.2 255.255.255.0
duplex auto
speed auto
duplex auto
speed auto
router bgp 900
no synchronization
network 192.168.1.0
neighbor 172.16.1.1 remote-as 100
neighbor 192.168.1.2 remote-as 900
no auto-summary
R4 Config
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
ip address 172.17.1.2 255.255.255.0
duplex auto
speed auto
router bgp 900
synchronization
network 192.168.1.0
neighbor 172.17.1.1 remote-as 100
neighbor 192.168.1.1 remote-as 900
no auto-summary
7 Replies 7
Mark Malone
wheres the configs to check the issue
R1 Config
duplex auto
speed auto
duplex auto
speed auto
router bgp 100
no synchronization
no auto-summary
R2 Config
duplex auto
speed auto
duplex auto
speed auto
router bgp 100
no synchronization
no auto-summary
R3 Config
duplex auto
speed auto
duplex auto
speed auto
router bgp 900
no synchronization
network 192.168.1.0
no auto-summary
R4 Config
duplex auto
speed auto
duplex auto
speed auto
router bgp 900
synchronization
network 192.168.1.0
no auto-summary
R4 should have:
neighbor 192.168.1.1 next-hop-self
The same for R5
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
there needs to be static routing or IGP configuration for that subnet, BGP is not a routing protocol its a transport protocol it needs and IGP or at least static routing to route traffic , the f0/0 is an internal ip not ebgp so it needs to be advertised by IGP into BGP so it can be reachable to the other ASs that's why you cant reach it
Julio E. Moisa
Do you have a valid entry for R4'networks into the routing table on R1 and vice versa? or have you included the command: next-hop-self on R4 and R5?
Is possible to share the configuration of each device and the show ip route or show bgp outputs?
Hello
In addition to the other  posts - Possibly also suggest
As RTR1 is an IBGP peer to RTR2/3 - Make RTRs 2 -3 the next-hop for R1 as by default ebgp prefixes with be advertised to rtr 1 with the ip address of the originator rtr and if you dont have any IGP for those networks then connectivity it will fail and this will be applicable the the ibgp rtrs on the other side also.
Example:ibgp for
RTR2/RTR3
Neighbor  <rtr1> next hop-self
res
Paul
Kind Regards
Paul
Hi Team,
We are getting below massage while configuring the secondary IP address on vlan interface, please suggest what it means of this message.Thanks.!
