BGP Timers with VRF
Peter Valdes
Level 3
Level 3
Just a quick one with regards to BGP Timers. As we all know its default Keepalives: 60 and Holdtime: 180 seconds.
I have the following config below setup on my network:
router bgp YYY
 bgp router-id 10.79.250.141
 bgp log-neighbor-changes
 neighbor 10.79.5.2 remote-as XXX
 neighbor 10.79.5.2 transport path-mtu-discovery
 neighbor 10.79.252.74 remote-as YYY
 neighbor 10.79.252.74 transport path-mtu-discovery
 address-family ipv4
  redistribute connected
  neighbor 10.79.5.2 activate
  neighbor 10.79.5.2 send-community
  neighbor 10.79.5.2 soft-reconfiguration inbound
  neighbor 10.79.252.74 activate
  neighbor 10.79.252.74 send-community
  neighbor 10.79.252.74 soft-reconfiguration inbound
 exit-address-family
 address-family ipv4 vrf admin
  neighbor 10.65.5.2 remote-as XXX
  neighbor 10.65.5.2 transport path-mtu-discovery
  neighbor 10.65.5.2 activate
  neighbor 10.65.5.2 send-community
  neighbor 10.65.5.2 soft-reconfiguration inbound
  neighbor 10.65.252.74 remote-as YYY
  neighbor 10.65.252.74 transport path-mtu-discovery
  neighbor 10.65.252.74 activate
  neighbor 10.65.252.74 send-community
  neighbor 10.65.252.74 soft-reconfiguration inbound
 exit-address-family
address-family ipv4 vrf av
  neighbor 10.78.5.2 remote-as XXX
  neighbor 10.78.5.2 transport path-mtu-discovery
  neighbor 10.78.5.2 activate
  neighbor 10.78.5.2 send-community
  neighbor 10.78.5.2 soft-reconfiguration inbound
  neighbor 10.78.252.74 remote-as YYY
  neighbor 10.78.252.74 transport path-mtu-discovery
  neighbor 10.78.252.74 activate
  neighbor 10.78.252.74 send-community
  neighbor 10.78.252.74 soft-reconfiguration inbound
 exit-address-family
Instead of me adding "neighbor x.x.x.x timer 30 90" on each peering neighbors, can I use "timers bgp 30 90" under the "router bgp 65258" to reflect to all address-family VRFs peering BGP neighbors?
If not, is there a global command to use to set the timers for all BGP session within the router?
Hi again,
Yes you have understood the concept.
Just set the timers after the bgp
router bgp 100
timers bgp 5 15 (Your own values)
This will set all neighbors to 5 15 unless you specifically set them in the neighbor statements
Hope this helps
Please grade useful posts
Alex
Regards, Alex. Please rate useful posts.
acampbell
The command
router bgp 100
neighbor 192.168.100.254 timers 30 90
This overides the command set under the timers bgp
router bgp 100
timers bgp 5 15
  neighbor 10.78.5.2 timers 30 90
 et etc etc
 exit-address-family
The result will be 30 90 for the vrf av neighbor but 5 15 for any others
See this link for more info
http://www.cisco.com/c/en/us/td/docs/ios/iproute_bgp/command/reference/irg_book.html
Alex
Thanks Alex. So if I left it as using "timer bgp 5 15" and no neighbor x.x.x.x timers setup, this should take affect to all vrf/neighbors globally for that router?
Much appreciate your reply and link.
Hi again,
router bgp 100
Hope this helps
Alex
