Showing results forĀ
Search instead forĀ
Did you mean:Ā
Big problem port channel bloked same vlans
salah gobbaa
Hi all,
we have this design in my network:
  • Switches staking connceted 2960X to Core switch 4507.
  • Tahre two links between the access switchs (stacking) and the core switch configured in etherchannel on  mode.
evry time we have a a traffik bloked in same vlan for example in vlan camera or vlan voice.This problem is solved only when I restart the stack.
any one can help me please?
Salah
13 Replies 13
salah gobbaa
any help
We are working on finding an answer to your question.
Kelli Glass
Moderator for Cisco Customer Communities
Have you checked STP configuration to determine what VLAN traffic is allowed/blocked?
Hi Jaston,
I used the MSTP with two instances(mode vtp) and in the etherchannel ports all vlans are allowed except vlan id1 .
and if you can assiste me?  how can i check STP configuration to determine what VLAN traffic is allowed.
Thank you for your help.
Try show spanning-tree mst [interface-id] in priveledge EXEC mode. Show running-config can also help.
Hi Jason,
find below
sh spanning-tree mst interface po1 and show running config.
and when I apply this config the situation becomes more stable but still there are problems
interface GigabitEthernet1/0/25
switchport trunk native vlan 32
switchport trunk allowed vlan 2-4094
switchport mode trunk
ipv6 traffic-filter NoIPv6 in
keepalive 10
channel-group 1 mode on
ACCESS-SW#sh spanning-tree mst interface po1
Port-channel1 of MST0 is root forwarding
Edge port: no             (default)        port guard : none        (default)
Link type: point-to-point (auto)           bpdu filter: disable     (default)
Boundary : internal                        bpdu guard : disable     (default)
Bpdus sent 7816, received 413564
Instance Role Sts Cost      Prio.Nbr Vlans mapped
0        Root FWD 20000     128.456  1-2,5-9,13-15,19,29,31,33-47,49-63
                                     65-67,69-71,75-79,81-95,97-99,101-111
                                     113-127,129-143,145-161,169-171,177-191
                                     209-215,217-219,248-251,254-299,302-309
                                     380-999,1001-1253,1255-4094
1        Root FWD 20000     128.456  3-4,10-12,16-18,20-28,30,32,48,64
                                     68,72-74,80,96,162-168,172-175,208
                                     216,220-247,252-253,310-363,366-379
2        Root FWD 20000     128.456  100,112,128,144,176,192-207,300-301
                                     364-365,1000,1254
ACCESS-SW#
ACCESS-SW#sh run
ACCESS-SW#sh running-config
Building configuration...
Current configuration : 28252 bytes
! Last configuration change at 15:14:54 UTC Mon Nov 27 2017 by 0netech
! NVRAM config last updated at 15:17:00 UTC Mon Nov 27 2017 by 0netech
version 15.2
no service pad
service password-encryption
hostname ACCESS-SW
boot-start-marker
boot-end-marker
enable secret 5 $1$nCDs$9u9iSHHjM7.3OfQMKPyoz/
enable password 7 070C285F4D06485744
username 0netech password 7 11595D4F56515946557D
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
switch 2 provision ws-c2960x-48ts-l
switch 3 provision ws-c2960x-48fps-l
switch 4 provision ws-c2960x-24ps-l
ip dhcp snooping vlan 1-4094
ip domain-name FourSeasons.com
mls qos
crypto pki trustpoint TP-self-signed-2808983040
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2808983040
revocation-check none
rsakeypair TP-self-signed-2808983040
crypto pki certificate chain TP-self-signed-2808983040
certificate self-signed 01
        quit
spanning-tree mode mst
spanning-tree mst configuration
name TSHMST
revision 2
instance 1 vlan 3-4, 10-12, 16-18, 20-28, 30, 32, 48, 64, 68, 72-74, 80
instance 1 vlan 96, 162-168, 172-175, 208, 216, 220-247, 252-253, 310-363
instance 1 vlan 366-379
instance 2 vlan 100, 112, 128, 144, 176, 192-207, 300-301, 364-365, 1000
instance 2 vlan 1254
spanning-tree mst 1 priority 4096
spanning-tree mst 2 priority 8192
no spanning-tree vlan 1011-1205,1254
spanning-tree vlan 1-4094 priority 4096
vlan internal allocation policy ascending
lldp run
interface Port-channel1
description ### uplink to core ###
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
description ***ACCESS CONTROL***
switchport access vlan 73
switchport mode access
speed 100
duplex full
spanning-tree portfast
interface GigabitEthernet1/0/3
description ***conneceted to GTC***
switchport access vlan 68
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description ### To Reception Desktops ###
switchport access vlan 16
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
description ***DAB**
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
description **printers**
switchport access vlan 4
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
speed 100
duplex full
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
speed 100
duplex full
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport access vlan 176
interface GigabitEthernet1/0/24
speed 100
duplex full
keepalive 10
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet2/0/1
description ****access to Workstations***
switchport access vlan 3
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
description ***tv**
interface GigabitEthernet2/0/38
description ***tv**
interface GigabitEthernet2/0/39
switchport access vlan 161
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/0/49
shutdown
interface GigabitEthernet2/0/50
interface GigabitEthernet2/0/51
interface GigabitEthernet2/0/52
interface GigabitEthernet3/0/1
switchport access vlan 208
speed 100
duplex full
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
power inline never
speed 100
duplex full
interface GigabitEthernet3/0/4
speed 100
duplex full
interface GigabitEthernet3/0/5
speed 100
duplex full
interface GigabitEthernet3/0/6
speed 100
duplex full
interface GigabitEthernet3/0/7
speed 100
duplex full
interface GigabitEthernet3/0/8
speed 100
duplex full
interface GigabitEthernet3/0/9
speed 100
duplex full
interface GigabitEthernet3/0/10
speed 100
duplex full
interface GigabitEthernet3/0/11
speed 100
duplex full
interface GigabitEthernet3/0/12
speed 100
duplex full
interface GigabitEthernet3/0/13
speed 100
duplex full
interface GigabitEthernet3/0/14
speed 100
duplex full
interface GigabitEthernet3/0/15
speed 100
duplex full
interface GigabitEthernet3/0/16
speed 100
duplex full
interface GigabitEthernet3/0/17
speed 100
duplex full
interface GigabitEthernet3/0/18
speed 100
duplex full
interface GigabitEthernet3/0/19
speed 100
duplex full
interface GigabitEthernet3/0/20
speed 100
duplex full
interface GigabitEthernet3/0/21
speed 100
duplex full
interface GigabitEthernet3/0/22
speed 100
duplex full
interface GigabitEthernet3/0/23
speed 100
duplex full
interface GigabitEthernet3/0/24
speed 100
duplex full
interface GigabitEthernet3/0/25
switchport trunk native vlan 48
switchport trunk allowed vlan 3,17,18,28,48,96,112,128,144,176,216,1254
interface GigabitEthernet3/0/26
interface GigabitEthernet3/0/27
interface GigabitEthernet3/0/28
interface GigabitEthernet3/0/29
interface GigabitEthernet3/0/30
interface GigabitEthernet3/0/31
interface GigabitEthernet3/0/32
interface GigabitEthernet3/0/33
interface GigabitEthernet3/0/34
interface GigabitEthernet3/0/35
interface GigabitEthernet3/0/36
interface GigabitEthernet3/0/37
interface GigabitEthernet3/0/38
interface GigabitEthernet3/0/39
interface GigabitEthernet3/0/40
interface GigabitEthernet3/0/41
interface GigabitEthernet3/0/42
interface GigabitEthernet3/0/43
interface GigabitEthernet3/0/44
interface GigabitEthernet3/0/45
interface GigabitEthernet3/0/46
interface GigabitEthernet3/0/47
description ***FINGERPRINT***
switchport access vlan 167
interface GigabitEthernet3/0/48
speed 100
duplex full
interface GigabitEthernet3/0/49
interface GigabitEthernet3/0/50
interface GigabitEthernet3/0/51
interface GigabitEthernet3/0/52
interface GigabitEthernet4/0/1
description ****Access to VOIP-WIRED***
switchport access vlan 80
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/3
interface GigabitEthernet4/0/4
interface GigabitEthernet4/0/5
interface GigabitEthernet4/0/6
interface GigabitEthernet4/0/7
speed 100
duplex full
interface GigabitEthernet4/0/8
interface GigabitEthernet4/0/9
interface GigabitEthernet4/0/10
interface GigabitEthernet4/0/11
interface GigabitEthernet4/0/12
interface GigabitEthernet4/0/13
interface GigabitEthernet4/0/14
interface GigabitEthernet4/0/15
interface GigabitEthernet4/0/16
interface GigabitEthernet4/0/17
interface GigabitEthernet4/0/18
interface GigabitEthernet4/0/19
interface GigabitEthernet4/0/20
interface GigabitEthernet4/0/21
interface GigabitEthernet4/0/22
interface GigabitEthernet4/0/23
interface GigabitEthernet4/0/24
interface GigabitEthernet4/0/25
keepalive 10
interface GigabitEthernet4/0/26
interface GigabitEthernet4/0/27
interface GigabitEthernet4/0/28
interface Vlan1
no ip address
shutdown
interface Vlan32
ip ssh version 2
snmp-server group SNMP-AUTH v3 auth read SNMP-VIEW write SNMP-VIEW
snmp-server group TSH@trap2017 v3 auth
snmp-server view gtk iso included
snmp-server view SNMP-VIEW iso included
snmp-server community switchback RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps cluster
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps power-ethernet group 3
snmp-server enable traps power-ethernet group 4
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 10.36.35.10 version 3 auth TSH@trap2017
snmp-server host 172.27.1.1 switchback  snmp
no vstack
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login
end
hi,
Problem for this Vlan CCTV 208: I cannot ping this vlan from anther switch but I can pinging from the same stack switch TSHSAD511
TSHSAD511#sh spanning-tree mst interface port-channel 1
Bpdus sent 20, received 219075
0        Root FWD 10000     128.456 1-2,5-9,13-15,19,29,31,33-47,49-63
1        Root FWD 10000     128.456  3-4,10-12,16-18,20-28,30,32,48,64
2        Root FWD 10000     128.456 100,112,128,144,176,192-207,300-301
                                     364-365,1000,1254
TSHSAD511#
TSHSCORE#sh spanning-tree mst interface port-channel 18
Port-channel18 of MST0 is designated forwarding
Portfast : no             (default)        port guard : none        (default)
PVST Sim : enable         (default)
Bpdus sent 219056, received 20
0        Desg FWD 10000     128.1298 1-2,5-9,13-15,19,29,31,33-47,49-63
1        Desg FWD 10000     128.1298 3-4,10-12,16-18,20-28,30,32,48,64
2        Desg FWD 10000     128.1298 100,112,128,144,176,192-207,300-301
                                     364-365,1000,1254
Question: Are all port channels encapsulated dot 1 q? Also re-verify that all of your configured VLANā€™s still exist.
yes all vlan are allowed in etherchannel ports and the bellow example configuration for etherchannel ports:
keepalive 10
keepalive 10
HI all,
any update please for my problem??
best regards
Salah
Is all traffic blocked for VLAN Voice and VLAN Camera or is ā€˜someā€˜ VLAN Voice/Camera able to transmit over the etherport? is port security configured for any of the interfaces?
hi,
you will find below two examples for a vlan camera interface and one for vlan telephony and all vlan traffic cameras and vlan phone are stuck for this switch stack
speed 100
duplex full
How many devices are communicating over the ether channel? Also please check your syslogs for error messages when the issue occurs.
