Big problem with 2960S-24TS-S
newskydata
I have a new switch 2960S-24TS-S trunking to 3750G (3750G working great). Currently I have big problem with switch 2960S then
Some time, all servers on sw 2960S downtime ~ 4-5m after uptime again
I checked then see that 1 server got SYN FLOOD attack ~ 60Mbps, but all servers down although on sw 2960S have many diffrent VLANs
# sh ver
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960S-24TS-S   12.2(55)SE7           C2960S-UNIVERSALK9-M
I have some switches 2960-24TT-L then haven't get above error like 2960S and working great.
*    1 26    WS-C2960-24TT-L    12.2(55)SE5           C2960-LANBASEK9-M
Any body help me ? Thanks so much ! Sorry so bad english  !
14 Replies 14
Leo Laohoo
You mean your severs connected to the 2960S will go down/up regularly?
Yeap,
All servers connected to 2960S will go down/up although only once server getting attacked. And have many VLANs on SW
And I also can't connect to SW 2960S via SSH v2 when once server being attacked
Post the "sh logs".
Hi Leo,
I see that gi 0/7 auto up down
# sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 800 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 800 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 803 message lines logged
Log Buffer (4096 bytes):
d state to down
*Apr  6 00:25:38.044: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:25:40.398: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:25:41.399: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:26:37.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:26:38.447: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:26:40.796: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:26:41.797: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:43:00.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:43:04.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:43:06.064: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:43:07.071: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:43:09.503: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:43:10.505: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:44:06.388: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:44:07.395: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 00:44:09.791: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 00:44:10.793: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 02:23:47.199: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
*Apr  6 02:26:04.992: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
*Apr  6 03:03:14.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 03:03:19.051: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 03:03:22.464: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 03:03:23.466: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 03:03:25.862: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 03:03:26.863: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 03:03:43.834: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr  6 03:03:44.836: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr  6 03:03:47.200: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr  6 03:03:48.202: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr  6 03:09:46.972: %SYS-5-CONFIG_I: Configured from console by dokhanh on vty1 (203.162.100.19)
*Apr 10 05:23:21.825: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr 10 05:23:22.826: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr 10 05:23:25.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr 10 05:23:28.210: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr 10 05:23:30.806: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr 10 05:23:31.807: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
*Apr 10 05:23:49.392: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to down
*Apr 10 05:23:50.393: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to down
*Apr 10 05:23:52.794: %LINK-3-UPDOWN: Interface GigabitEthernet0/7, changed state to up
*Apr 10 05:23:53.806: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/7, changed state to up
Something is WRONG here.
Your description shows a 2960S while your "sh log" is either from a 2960G or a 3560G.  Which is which?
No, This is log messages of SW 2960S
No it's not.
2960S interface naming convention is EXACTLY like a 3750.
I'm not pedantic.  I want to know if Gi0/7 is a 2960G or a 3560G.
It's a port of WS-C2960S-24TS-S. And this switch got above problem. Port 0/7 connect to windows server. I'm using port 0/23 connect to SW 3750G mode trunking
You want to show log of 2960S or 3750G ?
Topology
                Trunking
3750G <------------------->2960S
Thank you so much
Ok, then.
Do this:
1.  Command:  test cable tdr interface Gi0/7;
2.  Wait for about 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gi0/7; and
4.  Post the output to #3.
TDR test last run on: April 11 01:53:45
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/7     1000M Pair A     0    +/- 0  meters Pair A      Normal
                Pair B     3    +/- 0  meters Pair B      Normal
                Pair C     1    +/- 0  meters Pair C      Normal
                Pair D     2    +/- 0  meters Pair D      Normal
Ok, thanks for the output.
I've got a suspicion you've got a faulty patch cord nearest Gi0/7.  Let me explain:
1.  Look at the Status.  It shows "Normal".  That's good.
2.  Look at the Length of the cable.  Notice Pair "A" is showing a distance of 0?  Pair A decides whether or not your link should go up or down.  Judging from the output to the "sh logs" earlier, this is your culprit.
Thanks Leo,
I will check it
But my main problem is some time I can't connect to switch and All server on switch is downed after 3-4m then all normal
are you using uplinkfast towards 3750G switch and portfast on ports facing servers?
Also are you using the same STP on all switches?
This is STP configuration of my switch
spanning-tree mode pvst
and all ports have setting like
interface GigabitEthernet0/7
switchport access vlan 865
switchport mode access
switchport port-security maximum 7
switchport port-security mac-address sticky
switchport port-security mac-address sticky 0025.90d3.b030 vlan access
switchport port-security mac-address sticky 0025.90d3.b031 vlan access
spanning-tree portfast
Some reports
#sh
spanning-tree
VLAN0800
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     001e.f662.f200
             Cost        15
             Port        24 (GigabitEthernet0/24)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    33568  (priority 32768 sys-id-ext 800)
             Address     08cc.68e3.9d80
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/24              Root FWD 4         128.24   P2p
VLAN0861
  Root ID    Priority    33629
             Address     0013.1aa9.1a80
             Cost        4
  Bridge ID  Priority    33629  (priority 32768 sys-id-ext 861)
             Aging Time  300 sec
Gi0/4               Desg FWD 4         128.4    P2p Edge
Gi0/6               Desg FWD 4         128.6    P2p Edge
VLAN0865
  Root ID    Priority    33633
             Cost        4
  Bridge ID  Priority    33633  (priority 32768 sys-id-ext 865)
             Aging Time  300 sec
Gi0/1               Desg FWD 4         128.1    P2p Edge
Gi0/2               Desg FWD 19        128.2    P2p Edge
Gi0/3               Desg FWD 4         128.3    P2p Edge
Gi0/5               Desg FWD 4         128.5    P2p Edge
Gi0/7               Desg FWD 4         128.7    P2p Edge
Gi0/8               Desg FWD 4         128.8    P2p Edge
Gi0/9               Desg FWD 4         128.9    P2p Edge
