Bill Of Material (BOM)
anwar.alhammad
Dears
I need Bill Of Material (BOM) for Main Part Number = WS-C3850-24T-E.
Thank you
anwar.alhammad
Dears,
Soft reminder
Thank you
syrehan
Hello Anwar,
Please check your email. I have created the BOM for you. Let me know if you need anything else. I am also sharing a pdf version here as well.
Please, i also need BOM for the below:
Part Number Qty
WS-C4500X-16SFP+ 2
CON-SNT-WSC16SFX 2
C4KX-PWR-750AC-R 2
C4KX-NM-BLANK 2
C4KX-PWR-BLANK 2
C4500X-IPB 2
CAB-BS1363-C15-UK 2
S45XU-39E 2
C1-WS3850-12S/K9 4
CON-SNT-38012SK9 4
S3850UK9-163 4
C3850-NM-2-10G 4
CAB-TA-UK 4
STACK-T1-50CM 4
CAB-SPWR-30CM 4
PWR-C1-BLANK 4
PWR-C1-350WAC 4
L-C3850-RTU= 4
L-C3850-12-S-E 4
C1FPCAT38503K9 4
CON-ECMU-C1FC3853 4
C1-PI-LFAS-2K3K-K9 4
C1-ISE-BASE-12P 4
C1F1VCAT38503-04 4
WS-C2960X-24PS-L 12
CON-SNT-WSC224SL 12
CAB-ACU 12
CAB-CONSOLE-USB 12
NETWORK-PNP-LIC 12
C2960X-STACK 12
CAB-STK-E-0.5M 12
WS-C2960X-24PD-L 2
CON-SNT-WSC604DL 2
CAB-ACU 2
CAB-CONSOLE-USB 2
NETWORK-PNP-LIC 2
C2960X-STACK 2
CAB-STK-E-0.5M 2
WS-C3560CX-12PC-S 14
CON-SNT-WSC312PC 14
CAB-TA-UK 14
ISR4331-V/K9 1
CON-SSSNT-ISR4331V 1
SL-4330-IPB-K9 1
SL-4330-UC-K9 1
NETWORK-PNP-LIC 1
MEM-4300-4GU8G 1
MEM-FLSH-4U16G 1
PWR-4330-AC 1
CAB-ACU 1
CAB-CONSOLE-USB 1
PVDM4-32 1
NIM-BLANK 4
FL-CUBEE-5 4
SL-4330-SEC-K9 1
SM-S-BLANK 1
CME-UL 100
CON-ECMUS-CMEULCTG 100
SISR4300UK9-316S 1
ISR4331-SEC/K9 2
CON-SSSNT-ISR4331S 2
SL-4330-IPB-K9 2
NETWORK-PNP-LIC 2
FL-4330-HSEC-K9 2
MEM-4300-4GU8G 2
MEM-FLSH-4U8G 2
NIM-2GE-CU-SFP 2
NIM-ES2-4 2
PWR-4330-AC 2
CAB-ACU 2
CAB-CONSOLE-USB 2
SL-4330-SEC-K9 2
SM-S-BLANK 2
SISR4300UK9-316S 2
CP-7821-K9= 50
CON-SNT-CP7821K9 50
AIR-CT3504-K9 2
CON-SNT-AIRCTRTK 2
LIC-CT3504-1A 70
CON-ECMU-LICCTCTA 70
AIR-CT3504-SW-8.5 2
CON-SNT-AIRWCT354 2
CAB-AC-C5-UK 2
PWR-115W-AC 2
AIR-AP1832I-E-K9C 35
CON-SNT-AIRAPEKC 35
AIR-CMX-CLD-CPA-1Y 35
AIR-AP-T-RAIL-R 35
AIR-AP-BRACKET-1 35
SW1830-MECPWP-K9 35
SFP-10G-SR= 34
GLC-SX-MMD= 48
  200
BE6M-M5-K9 2
CON-SNT-BE6MM5K9 2
BE6K-PSU 2
BE6K-RAIDCTRLR 2
BE6K-DISK 12
R2XX-RAID5 2
BE6K-RAM 6
BE6K-CPU 2
CAB-9K10A-UK 2
VMW-VS6-HYPPLS-K9 2
R-CBE6K-K9 2
CON-ECMU-RCBE6KK 2
BE6K-SW-11.5-XU 2
BE6K-START-UWL35 2
BE6K-UWL-STD 200
UCM-11X-UWLSTD 465
CON-ECMU-UCM11STD 200
UCXN-11X-SCPORTS 4
UCXN-11X-UWLSTD 465
LIC-EXP-E-PAK 2
LIC-EXP-GW 8
LIC-EXP-E 4
LIC-EXP-TURN 4
LIC-EXP-AN 4
LIC-SW-EXP-K9 8
LIC-EXP-SERIES 8
EXPWY-VE-E-K9 4
BE-11X-UWLS-STR 2
CON-ECMU-BE11WXUR 2
BE6K-UXL-START 2
EXPWY-VE-C-K9 4
SW-EXP-8.X-K9 2
BE6K-PAK 2
LIC-EXP-DSK 465
Awaiting your kind response.
if you are a Cisco Channel Partner, you would be able to login to CCW using your company email address or CCO account and make an estimate yourself. It is easy.
https://apps.cisco.com/Commerce/guest
