Binding Physical Interface With Tap Device
stamil18
How to bind the Virtual interface into physical interface.
the main objective for do this is i want to forward the packet to the virtual device to monitor the traffic
Tamil Valavan Shanmugam
chrihussey
Not sure what platform you want to do this on, but I assume using "span"/ port monitoring would meet your requirement. The link below is for 2960s, but the capability is generally available across all platforms.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swspan.html
Hope this helps
