2960 XR
adamgibs7
Level 6
Level 6
dears,
I have a 2960 XR switches with latest IOS on that but I don't see any control-plan command on the switch,
can anybody guide me the how we can control packets for control plan and data plane on 2960XR switches.
Is it the below command is in security risk rather than line vty 0 3 allowing 4 connection instead of 16
Line vty 0 15
exec-timeout 5
transport input ssh
thanks
Reza Sharifi
The control and data plane commands usually pertain to chassis-based switches and not so much to1ru small switches.
No, usually security is more concern about running SSH vs telnet and not the number of lines.
Reza Sharifi
Dear Reza,
NTP & Tacacs key password are they easily decrytable as it seem to me type 7, how we can secure them,
Tacacs should be internal to the network and not have access to the outside except for upgrades.
As for NTP, you can use ACL to allow access to only one or 2 devices.
Dear Reza,
Though the tacacs is internal to the network but the password can be easily seen how we can secure it,
Thanks.
