Blade switch 3120 Crash
edmond.chiu
One of my blade switch 3120 running version 122-50.SE3    crashed and recorded the following erroe message:
System returned to ROM by bus error at PC 0x5B5EA78, address 0x0
Can someone help to find the root cause of the crash?
Many thanks
Ivan Shirshin
From the "show stacks" it seems to be an error on accessing specific memory address 0x0:
Using flash:/crashinfo/crashinfo_1.
Cisco IOS Software, CBS31X0 Software (CBS31X0-UNIVERSAL-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 09:10 by prod_rel_team
Instruction Access Exception (0x0400)!
Since 0x0 is a valid address in "main" region, the error likely to be a parity problem. The mostly meaningless stack trace corresponds with such root cause.
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
 0x00000000  0x0FFFFFFF   268435456  Local  R/W    main
Parity errors are related to HW problems and with first occurrence it is recommended to monitor the blade.
  1. https://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a0080094793.shtml
  2. http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a0080094340.shtml
At the same time, I suggest to check extended crashinfo for more symptoms.
------------------ show flash: ------------------
Directory of flash:/
    3  drwx         512   Jan 6 2013 06:59:18 +08:00  crashinfo_ext
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Leo Laohoo
12.2(50)SE3
I wouldn't be using this IOS version.
The "sh tech" didn't give me much information.  If the blade crashed then there should be some crashinfo files/folder.  Attached the latest 3.
Ivan Shirshin
Region Manager:
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
