Block BT configuration
shahaij
Level 3
Level 3
My router is Cisco 1721 and I want to implement block BT function on it by NBAR feature. But seems fail to do it. The following is my configuration. Is there any problem with it? Thanks a lot.
Router#show version
IOS (tm) C1700 Software (C1700-IPBASE-M), Version 12.3(6f), RELEASE SOFTWARE (fc1)
System image file is "flash:c1700-ipbase-mz.123-6f.bin"
cisco 1721 (MPC860P) processor (revision 0x500) with 55643K/9893K bytes of memory.
Router#show run
Current configuration : 1644 bytes
version 12.2
no parser cache
service config
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
logging rate-limit console 10 except errors
enable secret 5
ip subnet-zero
ip cef
ip nbar pdlm bittorrent.pdlm
ip nbar pdlm eDonkey.pdlm
no ip domain-lookup
no ip dhcp-client network-discovery
class-map match-all bittorrent
match protocol bittorrent
class-map match-all edonkey
match protocol edonkey
policy-map limit-bt
class bittorrent
police 8000 1500 1500 conform-action drop exceed-action drop violate-action drop
class edonkey
controller E1 0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
interface Ethernet0/0
ip address ....
ip access-group 101 in
ip nbar protocol-discovery
half-duplex
service-policy input limit-bt
service-policy output limit-bt
interface Serial0/0:0
ip address ....
interface Ethernet1/0
ip address ....
half-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 y.y.y.y
ip route y.y.0.0 255.255.0.0 x.x.x.x
ip http server
access-list 101 deny tcp any any range 6881 6890
access-list 101 deny udp any any range 6881 6890
access-list 101 deny tcp any range 6881 6890 any
access-list 101 deny udp any range 6881 6890 any
access-list 101 permit ip any any
line con 0
line aux 0
line vty 0 4
line vty 5 15
no scheduler allocate
end
Sha
carenas123
Level 11
Level 11
In the configuration given,
policy-map limit-bt
class bittorrent
class edonkey
why you have given the POLICE key word, Instead you can simply specify to drop
Sir,
I tried but it seems there is no directly 'drop' command here. That's why I use this method.
Thanks.
Sha
