Block Cascated Hub
ifabrizio
Level 3
Level 3
Dear All,
I have a 3750-48TS at Access layer, I'd like to prevent that someone try to connect on the fastethernet ports some Hubs,How can I do that?
I have just configured the ethernet ports with the commands "switchport mode access" to prevent trunk on them.
Could you help me pls.
BR.
Igor.
aijaz802
You can use "switchport port-security" command to limit the number of pcs to connect to this port and thru mac address restrictions.
Please check the link for more information....
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sed/command/reference/cli3.html
Pls. rate if it helps...
*aijaz*
Jon Marshall
Hi Igor
We use port-security on our switches to stop people connecting hubs to the switch ports. We allow 1 mac-address only on each port which means that if a user connects in a hub to use multiple machines the port will shutdown.
Have a read of port security on the 3750 and please come back with any further questions
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/configuration/guide/swtrafc.html#wp1038501
Jon
