Block port 3389 MSTSC Cisco 3560x
Good Afternoon
I am not an expert in Cisco so i would like some help from you guys (the experts).
I need to block port 3389 in a 3560x L3 switch
my idea for this was to make an access-list:
ip access-list extended BLOCK_RDP
deny   tcp any eq 3389 105.103.28.0 0.0.0.255
When i apply this on the interface the network goes down behind the L3 switch.
When i apply also the permit ip any any in the access list i can set up remote access again, and i dont want that.
Does anyone have an idea ?
these are the interfaces it is about
interface GigabitEthernet0/3
switchport mode trunk
interface GigabitEthernet0/4
Thanks a lot!
2 Accepted Solutions
John Blakley
Are you wanting to block this inter-vlan or within the same vlan?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Glad to hear you got it working. You can permit that address before the deny statement to allow them through. In your example, you could do:
ip access-list ext BLOCK_RDP
1 permit tcp host 105.103.24.110 105.103.28.0 0.0.0.255 eq 3389
2 permit tcp host 105.103.24.110 host 105.103.28.33 eq 3389
The line numbers are there because by default Cisco starts with 10. To insert a line where you want, you add the number. Line 1 will allow 105.103.24.110 to access anything int the 105.103.28.0/24 subnet, and line 2 will allow the same host to access ONLY 105.103.28.33 on that subnet connecting to RDP.
When you insert lines like this, it doesn't affect the existing traffic, and you don't have to remove the acl from the interface in order to modify it. So, in my example, you can insert the lines and when you look at your access-list, you would see:
10 deny   tcp any any eq 3389
20 permit ip any any
Make sense?
HTH,
John
5 Replies 5
John Blakley
HTH,
John
at this moment i have it working,
permit ip any any
interface Vlan28
description [* ADM 1F *]
ip address 105.103.28.1 255.255.255.0
ip access-group BLOCK_RDP out
do you have an idea ?
interface Vlan28
I can't access a computer in the 105.103.28.0/24 with mstsc, but i can access from the subnet 105.103.28.0/24 to other computers/subnets.
so that problem is solved, but i have one more question, when i want to give access to someone that want's to go by rdp to the 105.103.28.0/24 network, how do i set this in the ACL ?
i am not good with the wild card mask.
For example i would like to access with ip 105.103.24.110/24 to a computer in the 105.103.28.0/24 subnet.
Make sense?
HTH,
John
yes i understand.
Thank you so much for your explanation i did not know about that.
My problem is solved
Have a great day!
You too! Thank you for the rating
HTH,
John
