Block Printers
Najeeb Stanikzai
Community Member
Hello All,
i have a question. how can i block printing on subnet or vlan on Cisco switch
i would like to block 172.16.20.1 0.0.3.255 subnet to not print.
the printers ips are 172.16.12.20
172.16.12.21
172.16.12.22
2 Accepted Solutions
you can use this below ACL.
ip access-list extended blockprinter
 deny   ip 172.16.20.0 0.0.3.255 172.16.12.20 0.0.0.3
 permit ip any any
VS.Suresh.
*Plz rate the usefull posts *
***********Plz do rate this post if you found it helpful*************************
Which switch has the SVI for the 172.16.20.x network ?
So on a 172.16.20.x client what is the default gateway on that client ie. what IP address.
You need to find the switch with an "interface vlan <x>" with that IP address configured.
Then you need to apply the acl Suresh provided eg -
int vlan <x>
ip address 172.16.20.x 255.255.252.0
ip access-group blockprinter in
Jon
9 Replies 9
Leo Laohoo
You have two choices:
1.  You have three IP addresses, so you can create an ACL which includes the three IP address from contacting the printer server.
2.  Or you can create an ACL for the entire subnet.
can you please tell me the commends ? to block only printers
Read THIS.
if you can please tell me the exact command that will be good.
 permit ip any any
VS.Suresh.
do i need to create this access list in core switch ?
it is still allow, it did not block the printers.
i have tested it both in core switch and client switch it did not block printers.
int vlan <x>
Jon
Thanks, it has blocked,
Thank you Suresh,
i would like to setup VOIP for my office, can you please tell me what is the requirements.
