10-05-2017 02:34 AM - edited 03-08-2019 12:16 PM
Hello People,
Hope things going well.
Please refer the image in which i have designed a complete infrastructure and things are working fine. In the diagram given I have applied the ACL'S in such a way that Vlans 10,20,30 network of Mumbai should not communicate with Vlans 10,20 network of Delhi. Here i have given full provision for IT department (Vlan 40 in mumbai and Vlan 30 in Delhi) to communicate with each other.
But I have encountered some problem, reacheability from IT department to any other department in a different location is not possible. To clar my self if I try to reach vlan 10 network in delhi from vlan 40 network from Mumbai i get "Request timed out"as a response.
So in turn what I observed is my IT department vlans of the network 192.168.40.* in Mumbai and 10.10.30.* in Delhi cannot communicate with any other Vlan located in different location.
Can anyone please tell me how to resolve this issue.
Mumbai Location
Delhi Location
Ping Report from IT vlan 40 to vlan 10 of Delhi
Ping from valn 30 from Mumbai to vlan 10 of delhi (Suceessfully implemented)
Solved! Go to Solution.
10-05-2017 03:10 AM
10-07-2017 10:09 AM - edited 10-07-2017 10:16 AM
Hi Paul,
Thank you for assist.
But the code you have provided have landed me at same issue which I was facing before.
I have succesfully acomplished my task with little modification in objective.
In my infrastrcuture now i have implemented ACL's with the following objective to meet:
1) Here access list is designed in such a way that it will not allow vlan 10,20,30 of Mumbai to communicate with vlan 10,20 of Delhi.
2)All the Vlans of Mumbai can communicate with Vlan 30 of Delhi (also vice versa) and All the Vlans of Delhi can communicate with Vlan 40 of Mumbai (also vice versa).
3)So inshort we can state that IT Vlan (Vlan 40 of Mumbai and Vlan 30 of Delhi) have access to the entire infrastructure.
The below are the configs for the same:
Mumbai Router
MUM-RT01#sh run
Building configuration...
Current configuration : 1452 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname MUM-RT01
enable secret 5 $1$mERr$iReMtoOFQEl2wyGEfLcyU/
username ntw1 password 0 support
ip ssh version 2
ip domain-name abc.com
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.1
 encapsulation dot1Q 10
 ip address 192.168.10.100 255.255.255.0
 ip access-group nodelhi in
interface FastEthernet0/0.2
 encapsulation dot1Q 20
 ip address 192.168.20.100 255.255.255.0
interface FastEthernet0/0.3
 encapsulation dot1Q 30
 ip address 192.168.30.100 255.255.255.0
interface FastEthernet0/0.4
 encapsulation dot1Q 40
 ip address 192.168.40.100 255.255.255.0
interface FastEthernet1/0
 ip address 192.1.12.1 255.255.255.0
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.1.12.2
ip access-list extended nodelhi
 deny ip any 10.10.10.0 0.0.0.255
 deny ip any 10.10.20.0 0.0.0.255
 permit ip any any
logging 192.168.40.50
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
ntp server 192.168.40.50 key 0
end
Delhi Router
DELHI-CRT01#sh run
Current configuration : 1795 bytes
version 12.2
hostname DELHI-CRT01
enable secret 5 $1$mERr$V9qzj8j7axbG2be9Zsnei/
ip dhcp excluded-address 10.10.30.101 10.10.30.200
ip dhcp excluded-address 10.10.20.101 10.10.20.200
ip dhcp excluded-address 10.10.10.101 10.10.10.200
ip dhcp pool abc
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.100
 dns-server 10.10.30.40
ip dhcp pool abc2
 network 10.10.20.0 255.255.255.0
 default-router 10.10.20.100
ip dhcp pool abc3
 network 10.10.30.0 255.255.255.0
 default-router 10.10.30.100
username ntw2 password 0 assist
ip ssh version 2
 no ip address
 duplex auto
 speed auto
 ip address 10.10.10.100 255.255.255.0
 ip access-group nomumbai in
 ip address 10.10.20.100 255.255.255.0
 ip address 10.10.30.100 255.255.255.0
 ip address 192.1.45.5 255.255.255.0
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.1.45.4
ip access-list extended nomumbai
 deny ip any 192.168.10.0 0.0.0.255
 deny ip any 192.168.20.0 0.0.0.255
 deny ip any 192.168.30.0 0.0.0.255
 permit ip any any
no cdp run
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
Thnaks for the assist again.
10-05-2017 02:47 AM
Have you blocked the subnets in the acls you applied , if you remove the acl as a test do the subnets have reachability again ?
if its an acl issue provide the acls you have put in place and exactly where there applied
10-05-2017 03:06 AM
Hi Mark,
Thank you for your attention!
I haven't applied acl's on subnet. To clear myself i would like to share with you my configuration I have done.
MUM-RT01
MUM-RT01#sh run
Current configuration : 1659 bytes
version 12.2
hostname MUM-RT01
ip ssh version 2
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.5
 encapsulation dot1Q 1 native
 no ip address
 ip access-group 1 in
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
router bgp 100
 bgp log-neighbor-changes
 no synchronization
 neighbor 192.1.12.2 remote-as 200
 network 192.1.12.0
 network 192.168.10.0
 network 192.168.20.0
 network 192.168.30.0
 network 192.168.40.0
ip classless
access-list 1 deny 10.10.10.0 0.0.0.255
access-list 1 deny 10.10.20.0 0.0.0.255
access-list 1 permit any
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
Configuration for Delhi-CRT01 is attached. Kindly find the attachement.
Thank you
10-05-2017 03:10 AM
10-05-2017 10:38 AM
Hi Mark,
Thanks again, but please clear more myself regarding whether I should use BGP in the current topology?
My intention was to make my LAN reach to Internet., in this case it was 4.4.4.4 and 8.8.8.8.
I can achieve that via Bgp now my confusion is where to use BGP and if not bgp what instead of that? I understood it's transport protocol but was not aware about this behaviour of this protocol.
Should I use GRE tunneling? Also in a real scenario does everyone face the problem as I face it?
10-06-2017 01:13 AM
In real world design take a standard network you would use BGP when communicating with the ISP , in its internal LAN network it may use something like eigrp , the eigrp is then redistributed into the BGP off into the ISP, the ISP may then use MPLS to transport your networks accross its ISP network to your other office back into BGP and then back into the local IGP , the old rule of before a BGP route is advertised and added to the routing table, this route must be known via an IGP , its not GRE tunneling its routing you require the networks need to be in an IGP , this is standard design in the real world scenarios
office to office accross an ISP
LAN EIGRP into BGP -( ISP MPLS Network ) - BGP - EIGRP LAN
10-07-2017 10:15 AM
Hi Mark,
Thanks for the clarification for the real scenario.
You can check my reply below i have performed certain modification with configs and objectives both.
I have also made changes by removing BGP and implementing static route instead to achieve goals.
Thank you so much.
10-05-2017 10:40 AM
Hi Mark,
10-05-2017 03:06 AM
Hi Mark,
MUM-RT01
MUM-RT01#sh run
version 12.2
hostname MUM-RT01
ip ssh version 2
 no ip address
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router ospf 1
router bgp 100
 no synchronization
 network 192.1.12.0
ip classless
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
Thank you
10-06-2017 05:15 AM - edited 10-06-2017 05:17 AM
Hello
You need first to make sure these networks are reachable to/from each site, then you can apply a extended acl so it looks at the source and destination traffic to each sub interace of each vlan
Mumbai
ip access-list extended no-Delhi
deny ip 10.10.10.0 0.0.0.255 any
deny ip any 20.20.20.0 0.0.0.255
deny ip 20.20.20.0 0.0.0.255 any
deny ip any 30.30.30.0 0.0.0.255
deny ip 30.30.30.0 0.0.0.255 any
permit ip any any
ip access-list extended Delhi-vl30
permit ip any any
int fa0/0.1 to fa0/0/3
access-group no-Delhi in
access-group no-Delhi out
int fa0/0.4
access-group Delhi-vl30 in
access-group Delhi-vl30 out
Ammend to the above for Delhi as applicable
res
Paul
Hi Paul,
Mumbai Router
MUM-RT01#sh run
version 12.2
hostname MUM-RT01
ip ssh version 2
 no ip address
 duplex auto
 speed auto
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
ip classless
 permit ip any any
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
Delhi Router
DELHI-CRT01#sh run
version 12.2
ip dhcp pool abc
ip dhcp pool abc2
ip dhcp pool abc3
ip ssh version 2
 no ip address
 duplex auto
 speed auto
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
ip classless
 permit ip any any
no cdp run
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
