Bonding on different switch
zainal
Community Member
i have server that running openstack (kvm). For public, we have bonding nic (nic1,nic2). We plan to do redundancy for this bonding. The bonding using active-backup (active/passive) mode.
Nic1 will be active and nic2 is backup. Both nic connected to different switch. From what i found on the net, bonding active-backup normally using same switch but on different port channel. Is it possible to develop my plan? Advice needed.
Thanks.
Reza Sharifi
When bounding 2 different NICs from a server to a switch (or 2 if the switches are stacked or vss) The NICs need to be in the same Portchannel.
