Bootflash & Flash Corrupt
netbeginner
Level 6
Level 6
We having 7206 VXR NPE300 router, which is not booting up. bootflash & Flash memory card suspected to be corrupt. router is in rommon mode.
router is not supporting XMODEM pr TFTPDNLD command. please suggest to recover router ...
urgent help reuired.
iyde
Level 8
Level 8
Hi Sam.
If you do not have XMODEM or TFTPDNLD command available then your only option might be to use another router of the same model (NPE300) and make a set of new flash devices ready in that one and then move them to your faulty one.
I do not have access to a C7206 NPE300 so I can't verigy, but aren't here any commands to do a download to flash when you are in ROMMON - perhaps just named in another fashion?
HTH, Ingolf
