11-04-2013 09:08 PM - edited 03-07-2019 04:25 PM
Can someone please let me know the type of BPDU's is STP and their funtion ?
I just know that there are three types of BPDU's 1.configuration 2.Topology change notification 3. topology change ack.
It will be helpful if i get more info on this or a link to that .
Thanks in advance.
Chandu
Solved! Go to Solution.
11-05-2013 03:38 AM
Hi Chandu,
The authoritative source of information is the IEEE standard.
http://ylescop.free.fr/mrim/protocoles/802/802.1D-1998.pdf
Check the Section 9 starting at page 128. Regarding the addressing of TCN BPDUs, they are also sent to the same multicast MAC address as configuration BPDUs.
Best regards,
Peter
11-04-2013 09:21 PM
Hi Chandra,
Here is the url/info regarding the STP & Bpdu's
http://www.routeralley.com/ra/docs/stp.pdf
Kumar
11-05-2013 12:36 AM
To which address the BPDU's are sent ?
Chandu
11-05-2013 12:44 AM
Chandra,
Bridge Protocol Data Units (BPDUs) frames contain information regarding the Switch ID, originating switch port,MAC address, switch port priority, switch port cost etc.
Bridge Protocol Data Units (BPDUs) frames are sent out as multicast messages regularly at multicast destination MAC address 01:80:c2:00:00:00. When Bridge Protocol Data Units (BPDUs) are received, the Switch uses a mathematical formula called the Spanning Tree Algorithm (STA) to know when there is a Layer 2 Switch loop in network and determines which of the redundant ports needs to be shut down.
Three types of Bridge Protocol Data Units (BPDUs) are Configuration BPDU (CBPDU), Topology Change Notification (TCN) BPDU and Topology Change Notification Acknowledgment (TCA).
Inayath
11-05-2013 12:54 AM
Hi Inayath,
When a non-root switch is sending a TCN BPDU will it sent that to the multicast address or only to the root bridge through mac table ?
Chandu
02-22-2015 08:52 AM
Hi Chandra,
I will try answering your question, but I have not tested in Lab.
Non-root bridge , will try to deliver TCN Bpdu to root-bridge using Root-Bridge's mac address as all non-root-bridge switches would have mac address of Root-bridge-Switch in their mac-address-table already
11-05-2013 03:40 AM
Hello Inayath,
Technically, there are only two types of BPDUs in 802.1D STP: the Configuration BPDU with the Type = 0x00, and the TCN BPDU with the Type = 0x80. What is called TCA is simply a regular Configuration BPDU, Type = 0x00, with the TCA flag set.
Best regards,
Peter
11-05-2013 01:22 AM
Do we have any link which described only about BPDU frames ?
All the fields and types .
11-05-2013 03:38 AM
Hi Chandu,
Best regards,
Peter
