Bridge Assurance on 2960x
eekman
According to documentation on 2960x it supports Bridge Assurance on RSTP or MST networks. However, I cannot find any of the commands shown in the docs (page 32-33).
I recently connected a Nexus 3000 switch to a 2960x (IOS 15.0(2)) and Bridge Assurance on the Nexus blocked the port. I changed the config on the port from type network to normal and the block was lifted. So the 2960x does not seem to run Bridge Assurance, but I can't enable it either.
Why can't I find the commands on the 2960x? The switch has UDLD configured, should that config be removed if Bridge Assurance is used?
Erik,
on the 2960x, you need to run at least 15.2(4)E for 'spanning-tree bridge assurance'...
